Pull off your ultra high-res projects with the fast desktop storage. Break open bottlenecks and tighten up 4K–6K video workflows with blistering Thunderbolt 3 speeds and a reliable, industrial design.
Fast I/O
For the Bolt, LaCie harnessed the breakthrough performance potential of the Thunderbolt 3 I/O and paired it with the absolute fastest SSDs on the market. With a pair of M.2 PCIe SSDs striped together into a 2 TB volume, the result is astonishing speeds of up to 2,800 MB/s. -
For transfers in minutes, not hours
That kind of speed slashes time off nearly every task in your post-production workflow. Ingest RAW footage from RED or Blackmagic cinema cameras in a fraction of the time. Transcode 4/5/6K footage much faster using Adobe Premiere Pro or DaVinci Resolve. Then transfer a terabyte of footage from the Bolt to RAID storage - such as the LaCie 12big Thunderbolt 3 - in minutes instead of hours. -
The USB-C that does it all
Thunderbolt 3 brings Thunderbolt performance to USB-C connectivity at electrifying speeds of up to 40 Gb/s, creating a single compact port that does it all. Thunderbolt 3 permits daisy chaining and provides four times the data and twice the video bandwidth of any other cable, while also supplying power. -
To level up your workspace
This means you can daisy chain one USB-C (USB 3.1) or up to five Thunderbolt 3 devices, connect dual 4K displays, and even power a compatible laptop - all through a single USB-C cable connected to your computer. With two 4K displays, you can spread out your workspace by dedicating one display to your timeline and the other to previewing 4K footage, for example. Thunderbolt 3 delivers double the performance and versatility of any other interface. -
Aluminum enclosure
Each product is individually Computer Numerical Control machined from solid aluminum blocks for rigid durability and heat dissipation.
- LaCie Bolt3 - storage enclosure
- Storage enclosure
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Built-in Devices
- Led panel
- Hard Drive
- 2 x 1 TB SSD PCI Express
- OS Required
- Apple MacOS X 10.10 or later, Windows 8 or later
- Power
- AC 120/230 V - 50/60 Hz
- 11.5 cm x 2.5 cm x 20.3 cm
- 785 g
- 3-year warranty
- Storage enclosure
Chassis
- Built-in Devices
- Led panel
- 2
- Supported Devices / Modules Qty
- 2
- CPU
- No CPU
Hard Drive
- SSD
- Capacity
- 2 x 1 TB
- Interface Type
- PCI Express
- Expansion Bays
- 2 (total) / 0 (free) x internal - M.2
- 2 x Thunderbolt 3 - 24 pin USB-C
- OS Required
- Aluminum enclosure
- Cables Included
- 1 x USB-C cable
- Software Included
- Intego Backup Manager Pro, LaCie Private-Public
- AES-256
- Included Accessories
- Stand
- Voltage Required
- Power Provided
- 60 Watt
- 11.5 cm
- 2.5 cm
- 20.3 cm
- 785 g
- Limited warranty - 3 years
