Deadlines rule our world. When digital storage is critical for your project, it had better be as fast and reliable as you are. From the desktop to the badlands, it has to connect to any computer, deliver more than enough speed for the most demanding applications, and protect data against any threat.
Universal connectivity
Don't let your project get derailed by external drive/computer incompatibility. With both USB 3.0 and Thunderbolt interfaces, the LaCie Rugged is a perfect match for your Mac and PC. And because USB 3.0 is backwards compatible, you can connect it to any standard computer on the planet. The LaCie Rugged is also fully bus-powered through the included USB 3.0 and Thunderbolt cables. Its portability and interfaces make it the must-have sidekick to a new Mac or Ultrabook. -
No-compromise speed
Get lightning-fast transfer speeds on Mac and PC thanks to the USB 3.0 and Thunderbolt interfaces. Back up and transfer mountains of data in a fraction of the time. Enjoy noticeably more responsive photo library browsing.
- LaCie Rugged Thunderbolt - SSD - 250 GB - USB 3.0 / Thunderbolt
- Solid state drive - external (portable)
- Capacity
- 250 GB
- Interface
- Data Transfer Rate
- 10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
- Shock resistant, water resistant, rugged pocket-sized design, password authentication, dust-proof, automatic backup, software encryption, 256-bit AES
- Power Source
- USB bus, Thunderbolt bus
- 89 mm x 140 mm x 24 mm
- 280 g
- 3-year warranty
- Capacity
- 250 GB
- Interface
- Internal Drive Interface
- SATA 6 Gb/s
- 89 mm
- 140 mm
- 24 mm
- 280 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 387 MB/s
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- Software Included
- LaCie Backup Assistant, LaCie Private-Public
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
- Included Accessories
- Protective cover
- Cables Included
- 1 x Thunderbolt cable - integrated , 1 x USB 3.0 cable - external
- IP54
- Limited warranty - 3 years
