LaCie 24TB 6big RAID Thunderbolt3 & USB 3.1 [7200] Enterprise
Quicklinx: DCM9WS00 Mfr#: STFK24000400
Type: Hard drive array
Controller Type: RAID
Hurry, only 1 left in stock!
£1,790.19 ex VAT
£2,148.22 inc VAT
Think bigger - LaCie's got you covered. With up to 24TB of capacity on your desktop, and RAID 5/6, the LaCie 6big Thunderbolt 3 lets you rein in the stampede of data from ultra high resolution cameras.
LaCie 6big Thunderbolt 3 STFK24000400 - hard drive array
Hard drive array
Total Array Capacity
24 TB
USB 3.1, Thunderbolt 3
6 (installed) / 6 (max)
Supported Drives
SATA
Built-in Devices
Led panel
Storage Controller
RAID RAID 0, 1, 5, 6, 10, 50
Hard Drive
6 x 4 TB HDD - hot-swap - Enterprise Class Reliability, 24x7 continuous operation
Apple MacOS X 10.10 or later, Windows 8 or later
AC 120/230 V - 50/60 Hz
16.1 cm x 22.5 cm x 23.7 cm
9.3 kg
5-year warranty
Hard drive array
Chassis
Built-in Devices
Led panel
6
Supported Devices / Modules Qty
6
Supported Drives
SATA
Storage
24 TB
HDD Array External Interface
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
HDD - hot-swap
6 x 4 TB
Spindle Speed
7200 rpm
Expansion Bays
6 (total) / 0 (free) x hot-swap - 3.5"
2 x Thunderbolt 3 - 24 pin USB-C , 1 x USB 3.1 - 24 pin USB-C
Audible alarm, redundant fans, e-mail notification, kensington security slot
1 x USB-C cable , 1 x USB-C to USB-A cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
AES-256
Internal power supply
Power Provided
250 Watt
16.1 cm
22.5 cm
23.7 cm
9.3 kg
Limited warranty - 5 years
Brand: LaCie
Price Range Ex VAT: 1500+
