Product
LaCie 20TB 5big Thunderbolt2 / 7200RPM
Quicklinx: B3KKWS00 Mfr#: LAC9000503EK
For 4k and other bandwidth-hungry workflows, external storage needs to be fast, secure, reliable, and quiet. The LaCie 5big fits the bill, delivering thunderbolt 2 speeds for 4k video editing, up to 30 TB capacity, and hardware RAID 5/6 for no-compromise data security.
  • Thunderbolt 2 speeds for the 4k era
    Game-changing storage performance that accelerates workflows.
  • RAID for speed with security
    Hardware RAID for optimal performance with data security.
  • The powerful I/O, reinvented
    Doubles the speed and supports 4k workflows.
  • Advanced cooling for long-term reliability
    Efficient and near-silent cooling for a long-lasting product.
LaCie 5big Thunderbolt 2 - hard drive array
Hard drive array
Total Array Capacity
20 TB
Thunderbolt 2
5 (installed) / 5 (max)
Supported Drives
SATA-600
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
5 x 4 TB - hot-swap
Apple MacOS X 10.9 or later
AC 120/230 V - 50/60 Hz
17.3 cm x 19.6 cm x 22 cm
7.6 kg
Hard drive array
Chassis
5
Supported Devices / Modules Qty
5
Supported Drives
SATA-600
Storage
20 TB
HDD Array External Interface
Thunderbolt 2
Storage Controller
RAID
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
Hot-swap
5 x 4 TB
Spindle Speed
7200 rpm
Expansion Bays
5 (total) / 0 (free) x hot-swap - 3.5"
2 x Thunderbolt
Security lock slot (cable lock sold separately), Whisper Quiet Fan Technology
1 x Thunderbolt cable
Software Included
Intego Backup Manager Pro, LaCie Private-Public
AES-256
External power adapter
Power Provided
150 Watt
17.3 cm
19.6 cm
22 cm
7.6 kg
