Product
LaCie 1TB Rugged Tbt & USB 3.1 Type C
Quicklinx: D979WS00 Mfr#: STFS1000401
Form Factor: 2.5"
Capacity: 1TB
£360.75 ex VAT
£432.90 inc VAT
Deadlines rule our world. When digital storage is critical for your project, it had better be as fast and reliable as you are. From the desktop to the badlands, it has to connect to any computer, deliver more than enough speed for the most demanding applications, and protect data against any threat.
  • Universal connectivity
    Don't let your project get derailed by external drive/computer incompatibility. With both USB 3.0 and Thunderbolt interfaces, the LaCie Rugged is a perfect match for your Mac and PC. And because USB 3.0 is backwards compatible, you can connect it to any standard computer on the planet. The LaCie Rugged is also fully bus-powered through the included USB 3.0 and Thunderbolt cables. Its portability and interfaces make it the must-have sidekick to a new Mac or Ultrabook.
  • No-compromise speed
    Get lightning-fast transfer speeds on Mac and PC thanks to the USB 3.0 and Thunderbolt interfaces. Back up and transfer mountains of data in a fraction of the time. Enjoy noticeably more responsive photo library browsing.
LaCie Rugged Thunderbolt - solid state drive - 1 TB - USB 3.1 Gen 2 / Thunderbolt 3
Solid state drive - external (portable)
1 TB
USB 3.1 Gen 2 / Thunderbolt 3 - USB-C
Shock resistant, water resistant, dust-proof, rugged, port cover
Power Source
USB bus, Thunderbolt bus
88.9 mm x 140.1 mm x 25 mm
400 g
Worldwide
3 years warranty
1 TB
88.9 mm
140.1 mm
25 mm
400 g
Performance
Max Data Transfer Rate
510 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 2 - 24 pin USB-C , 1 x Thunderbolt 3
Power Source
Apple MacOS X 10.6.8 or later, Microsoft Windows 7 / Windows 8
Protective cover
1 x USB-C cable - external , 1 x USB-C to USB-A cable - external , 1 x Thunderbolt cable - integrated
IP54
Worldwide
Limited warranty - 3 years
Form Factor: 2.5"
Capacity: 1TB
Brand: LaCie
Price Range Ex VAT: 300 - 500
