Product
LaCie 1TB Porsche Design USB 3.0 Portable Hard Drive
Quicklinx: DDVZWS00 Mfr#: STET1000400
Form Factor: 2.5"
Capacity: 1TB
Stock Status: Clearance
48 left in stock
£41.66 ex VAT
£49.99 inc VAT
Express delivery Delivered on Tuesday
With the LaCie Porsche Design Mobile Drive's USB 3.0 interface, you'll be able to transfer files faster than ever before. Back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With speeds up to 100 MB/s, the possibilities are endless.
  • Accelerate your backup with USB 3.0
  • Porsche design form, LaCie function
    With the LaCie Mobile Drive, an exclusive and timeless shape was produced, with solid, reliable hardware that's sure to last for years. You can use it anywhere and be confident that you're getting superb performance.
  • Safe, strong, and aluminum
    With 3 mm of solid aluminum casing surrounding the disk inside, the LaCie Mobile Drive keeps your data solidly protected. LaCie and Porsche Design worked together to combine form and function-resulting in a drive that looks great (and works great!) no matter where you take it.
  • Designed for your Mac
    The LaCie Mobile Drive was designed especially for Mac computers, and features a stylish, sophisticated aluminum finish that matches your MacBook. Plus, it's Time Machine compatible so that you can seamlessly backup to the drive using Mac's built-in software.
LaCie Porsche Design Mobile Drive for Mac STET1000400 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Aluminium enclosure
77 mm x 130 mm x 15 mm
240 g
1 TB
USB 3.0
Aluminium enclosure
77 mm
130 mm
15 mm
240 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Software Included
Economy Mode (ECO) Setting Utility, LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.5 or later, Microsoft Windows 7 / 8 / 10
1 x USB 3.0 cable - external
Form Factor: 2.5"
Capacity: 1TB
Brand: LaCie
Price Range Ex VAT: 0 - 50
