Like an airy loft or vast landscape, LaCie Mobile Drive articulates the beauty and importance of premium space. LaCie Mobile Drive offers massive on-the-go space for everything worth storing and backing up. Even music, movies, and personal documents.
- LaCie Mobile Drive STHG1000400 - hard drive - 1 TB - USB 3.1 Gen 2
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.1 Gen 2 - USB-C
- Data Transfer Rate
- 10.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Power Source
- USB bus
- Enclosure Colour
- Silver moon
- 2-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.1 Gen 2
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.1 Gen 2 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.11 or later
- Cables Included
- 1 x USB-C 3.1 cable , 1 x USB-C to USB-A cable
- Enclosure Colour
- Silver moon
- Limited warranty - 2 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
F46R 043886 Condition: Customer return - item has been used and shows signs of use |
£43.04 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
