Beyond being rain, drop, and crush resistant, the LaCie Rugged USB-C is also backwards compatible with USB 3.0 and USB 2.0.
- LaCie Rugged USB-C - hard drive - 1 TB - USB 3.1 Gen 1
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.1 Gen 1 - USB-C
- Data Transfer Rate
- 5.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- Rugged pocket-sized design, rain-resistant, impact-resistant, crush-resistant
- Power Source
- USB bus
- 86 mm x 135.1 mm x 18.7 mm
- 100 g
- 2-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.1 Gen 1
- 86 mm
- 135.1 mm
- 18.7 mm
- 100 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 130 MB/s
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 24 pin USB-C
- Power Source
- USB bus
- Software Included
- LaCie Setup Assistant, LaCie Backup Assistant, LaCie Private-Public
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows 7 or later
- Limited warranty - 2 years
