With the redesigned 2big, instead of aiming for incremental, LaCie shot for revolutionary. Its excellent industrial design demolishes the status quo and sets a standard for versatility and reliability. The LaCie 2big also features unbeatable Thunderbolt 2 technology and hardware RAID for sensational performance.
Thunderbolt 2 speeds for the 4K era
With Thunderbolt 2 technology, the interface is no longer the performance bottleneck. For the 2big, LaCie harnessed the breakthrough performance potential of the Thunderbolt 2 I/O, squeezing the absolute best speeds out of the hard disks. Add a hardware RAID controller and 7200 RPM disks and the result is incredible, sustained speeds of up to 420 Mbps that turbocharger file transfers and backups. With this kind of speed, video graphics can edit multiple 2K uncompressed 10-bit streams or play back compressed 4K video. Digital photographers can browse a massive RAW photo library with zero lag. And, thanks to support for DisplayPort, it's now possible to daisy chain higher-resolution displays such as 4K monitors. -
Versatility for pro environments
With USB 3.0 and Thunderbolt 2 interfaces, the LaCie 2big gets the best possible speeds on any late-model PC or Mac. And, USB 3.0 backward compatibility means that you can connect the LaCie 2big to any standard computer. With support for exFAT and built-in hardware RAID, you can seamlessly connect to both PC and Mac computers without losing your RAID configuration. Thunderbolt 2 continues to support daisy chaining of up to six devices to a computer via a single cable. This means that professionals can daisy chain up to five LaCie 2bigs plus a 4K display to a computer, bringing capacity, incredible speed, and convenience. Thunderbolt 2 is also backward compatible and uses the same cables and connectors as first-generation Thunderbolt devices and computers. -
RAID for speed or security
In addition to compatibility with any computer, hardware RAID delivers sustained performance and better reliability. The LaCie 2big's range of RAID modes also gives you the flexibility to tailor the product to meet your needs. It's incredibly easy to change the RAID mode, but impossible to do so accidentally. You can leave it in RAID 0 (FAST) mode to maximize speed and capacity for working on current projects, and then move completed projects to archival storage incredibly quickly. Or configure the LaCie 2big in RAID 1 or mirroring (SAFE) mode, which provides data protection if one disk fails. And thanks to hot-swappable disks, you can simply replace a disk - from the front - with zero data loss and no work interruption. Even in RAID 1, impressive transfer speeds slash the time it takes to perform backups, making it easier to back up more frequently. The LaCie 2big even features JBOD, so you can see and use each disk independently.
- LaCie 2big Thunderbolt 2 - hard drive array
- Hard drive array
- Total Array Capacity
- 12 TB
- Interface
- USB 3.0, Thunderbolt 2
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Storage Controller
- RAID RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 6 TB HDD - hot-swap
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows 7 / Windows 8
- Power
- AC 120/230 V - 50/60 Hz
- 10.9 cm x 13 cm x 21.7 cm
- 3 kg
- Hard drive array
Chassis
- 2
- Supported Devices / Modules Qty
- 2
Storage
- 12 TB
- HDD Array External Interface
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, JBOD
Storage Controller (2nd)
- Data Transfer Rate
- 420 MBps
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 6 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 2 x Thunderbolt , 1 x USB 3.0
- OS Required
- Aluminum enclosure
- Cables Included
- 1 x Thunderbolt cable , 1 x USB cable
- Software Included
- Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Desktop Manager, LaCie Private-Public
- AES-256
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 60 Watt
- 10.9 cm
- 13 cm
- 21.7 cm
- 3 kg
