Fiber Channel DAS has been dethroned. Featuring Thunderbolt 2 speeds of up to 1330MB/s and 48TB in a 1U rackmount size, the LaCie 8big Rack has seized the crown. Video pros, meet the king of storage for 4K workflows.
Bulletproof reliability
With full component redundancy, the LaCie 8big Rack gives professionals superb reliability and data security. Fans, disks, and PSU are fully redundant, hot swappable, and user-serviceable. And hardware RAID 5/6 provides security against disk failure and data loss, without compromising on transfer speeds. Whatever the contingency, zero data loss, and zero downtime. Its innovative cooling system prolongs component lifespan, featuring three efficient, thermoregulated cooling fans to drive airflow. A metal sheet beneath the disks dissipates heat, and cool air flows under the sheet to drain hot air away. Above and between the two rows of disks, air flows from front to back, conducting heat away from sensitive components. -
Most powerful I/O, reinvented
Thunderbolt technology redefined external storage with its speed and versatility for bandwidth-intensive applications. Thunderbolt 2 builds on those advances by doubling the speed potential to 20Gb/s and enabling simultaneous RAW 4K video editing and display. And thanks to support for DisplayPort 1.2, it's now possible to daisy chain higher-resolution displays such as 4K monitors. In addition to higher performances, the Thunderbolt 2 I/O offers dramatically simpler connections than Fiber Channel. Connect the LaCie 8big Rack to a computer via the Thunderbolt cable - no HBA (host bus adapter) necessary - and instantly the volume mounts on your OS. -
Innovative design, breakthrough usability
The LaCie 8big Rack industrial design demolishes the status quo for rack storage, with a relentless focus on usability for professionals.
- LaCie 8big Rack Thunderbolt 2 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 1U
- Total Array Capacity
- 12 TB
- Interface
- Thunderbolt 2
- Installed Devices / Modules Qty
- 4 (installed) / 8 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Led panel
- Storage Controller
- RAID (SATA 6Gb/s) - RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 3 TB HDD - hot-swap
- OS Required
- Apple MacOS X 10.9 or later
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 47.7 cm x 77.2 cm x 4.4 cm
- 18 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Built-in Devices
- Led panel
- 4
- Supported Devices / Modules Qty
- 8
- Supported Drives
- SATA-600
Storage
- 12 TB
- HDD Array External Interface
- Thunderbolt 2
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- Max Storage Devices Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 3 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 8 (total) / 4 (free) x hot-swap - 3.5"
- 2 x Thunderbolt
- OS Required
- Redundant fans, aluminum enclosure, hot-swappable fans
- Cables Included
- 1 x Thunderbolt cable
- Software Included
- Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
- AES-256
- Power Device
- Internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- Power Provided
- 250 Watt
- 47.7 cm
- 77.2 cm
- 4.4 cm
- 18 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 10 - 60% (non-condensing)
- Sound Emission
- 50 dB
