LaCie 120TB 12big RAID Thunderbolt3 & USB 3.1 [7200] Enterprise
Quicklinx: DCMJWS00 Mfr#: STFJ120000400
Think bigger - we've got you covered. With ample capacity on your desktop, up to 2600MB/s speeds, and RAID 5/6, the LaCie 12big and 6big Thunderbolt 3 lets you rein in the stampede of data from ultra hi-res cameras.
  • Extremely fast I/O
    For the 6big and 12big, LaCie harnessed the breakthrough performance potential of the Thunderbolt 3 I/O and squeezed the absolute best speeds out of the hard drives. A hardware RAID controller was added and 7200RPM drives, and the result is astonishing 12big speeds of up to 2600MB/s - and 2400MB/s in RAID 5.
  • For lightning-fast video workflows
    That kind of speed can slash time off nearly every task in your post-production workflow. Ingest hours of RAW footage from a Blackmagic cinema camera into Adobe Premiere Pro in a fraction of the time. Then edit multiple streams of ProRes 422 (HQ), ProRes 4444 XQ, as well as uncompressed HD 10-bit and 12-bit video. For big projects packed with high-def clips, thumbnail and preview rendering becomes much more responsive.
  • And for your smartest workspace
    With double the video bandwidth of its predecessor, Thunderbolt 3 lets you daisy chain dual 4K displays or a single 5K display to the LaCie 12big or 6big. With two 4K displays, you can spread out your workspace by dedicating one display to your timeline and the other to previewing 4K footage, for example. It's even possible to power a compatible laptop through the Thunderbolt 3 connection.
LaCie 12big Thunderbolt 3 - hard drive array
Hard drive array
Total Array Capacity
120 TB
USB 3.1, Thunderbolt 3
12 (installed) / 12 (max)
Supported Drives
SATA
Built-in Devices
Led panel
Storage Controller
RAID RAID RAID 0, 1, 5, 6, 10, 50
Hard Drive
12 x 10 TB HDD - hot-swap - Enterprise Class Reliability, 24x7 continuous operation
Apple MacOS X 10.10 or later, Windows 8 or later
AC 120/230 V - 50/60 Hz
16.1 cm x 44.7 cm x 23.7 cm
17.6 kg
5-year warranty
Hard drive array
Chassis
Built-in Devices
Led panel
12
Supported Devices / Modules Qty
12
Supported Drives
SATA
Storage
120 TB
HDD Array External Interface
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
HDD - hot-swap
12 x 10 TB
Spindle Speed
7200 rpm
Expansion Bays
12 (total) / 0 (free) x hot-swap - 3.5"
2 x Thunderbolt 3 - 24 pin USB-C , 1 x USB 3.1 - 24 pin USB-C
Audible alarm, redundant fans, e-mail notification, kensington security slot
1 x USB-C cable , 1 x USB-C to USB-A cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
AES-256
Internal power supply
Power Provided
400 Watt
16.1 cm
44.7 cm
23.7 cm
17.6 kg
Limited warranty - 5 years
