Kyocera PF 470 Media 500 sheet tray / feeder - for Kyocera FS-6025, FS-6030, FS-6525, FS-6530, FS-C8020 and FS-C8025.
Versatile media handling
The Kyocera PF 470 media tray / feeder offers versatility with support for a wide range of media sizes including A3, A4, A5, ANSI A (Letter), B5, and Legal. This flexibility ensures that users can handle various printing tasks with ease, making it a suitable addition to any PC-compatible printing setup. -
Enhanced productivity
With a total media capacity of 500 sheets, the Kyocera PF 470 significantly enhances printing productivity. Users can enjoy longer periods of uninterrupted printing, which is beneficial in high-volume printing environments.
- Kyocera PF 470 - media tray / feeder - 500 sheets
- Product Type
- Media tray / feeder
- Total Media Capacity
- 500 sheets
- Number of Media Trays
- 1
- 59 cm x 59 cm x 35.2 cm
- 20 kg
- Media Type
- Plain paper
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm)
- Designed For
- Kyocera FS-6025, FS-6030, FS-6525, FS-6530, FS-C8020, FS-C8025; ECOSYS M4125, M4132, M8124, M8130
- Product Type
- 500 sheets
- 1
- Media Type
- Plain paper
- Media Sizes
- 59 cm - 59 cm - 35.2 cm
- 20 kg
- Designed For
- Kyocera FS-6025MFP, FS-6025MFP/Base, FS-6025MFP/FAX, FS-6025MFP/KL3, FS-6025MFP/KL3FAX, FS-6030MFP, FS-6030MFP/FAX, FS-6030MFP/KL3, FS-6030MFP/KL3FAX, FS-6525MFP/KL3, FS-6525MFP/KL3FAX, FS-6530MFP, FS-6530MFP/KL3, FS-6530MFP/KL3FAX, FS-C8020MFP, FS-C8020MFP/FAX, FS-C8020MFP/KL3, FS-C8020MFP/KL3FAX, FS-C8025MFP, FS-C8025MFP/FAX, FS-C8025MFP/KL3, FS-C8025MFP/KL3FAX , Kyocera ECOSYS M4125idn, M4125idn/KL3, M4132idn, M4132idn/KL3, M8124cidn, M8124cidn/KL3, M8130cidn, M8130cidn/KL2, M8130cidn/KL3
