In cases where productivity and efficiency are key, the powerful FS-2020D is your first choice. With 35 pages per minute it works at an remarkable pace, and also provides duplex printing, 500-sheet universal cassette and exceptional user friendliness as standard. With standard USB and parallel interface, the FS-2020D can be shared very easily, and the network model FS-2020DN is ideally suited for smaller workgroups.
Robust printing speed
Achieve up to 35 pages per minute with monochrome laser technology, ensuring efficient document production for busy workgroups. -
High-quality output
With a maximum resolution of 1200 DPI, this printer produces sharp text and detailed graphics to meet professional standards. -
Versatile media handling
Accommodate various media types and sizes including envelopes, labels, and transparencies with built-in support for A4 and Legal formats. -
Substantial paper capacity
A total input capacity of up to 1100 sheets minimizes downtime by reducing the frequency of paper refills, perfect for high-volume environments. -
Seamless connectivity
Easily connect through Ethernet, USB, and parallel interfaces, allowing for rapid integration into your existing office network.
- Kyocera FS-2020DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 16.2 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- Kyocera Image Refinement
- Automatic Duplexing
- Interface
- Parallel, USB, LAN, USB host
- Processor
- PowerPC 440 533 MHz
- RAM Installed (Max)
- 128 MB (1.125 GB) - DDR2 SDRAM - DIMM 144-pin
- Card Reader
- Language Simulation
- PCL 5C, PCL 6, EPSON LQ, Diablo 630, KPDL3, PRESCRIBE IIe, IBM ProPrinter X24e
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Envelopes, transparencies, labels, plain paper, recycled paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Apple MacOS 9.x, Microsoft Windows, Apple MacOS X 10.2 or later
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- 38.2 cm x 39.4 cm x 28.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9 sec
- Fonts Included
- 47 x barcode , 80 x PCL , 1 x bitmapped
- Barcodes
- Media Handling
- Processor
RAM
- 128 MB / 1.125 GB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 1100 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- 20000 pages
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x ExpressCard
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel , 1 x LAN - RJ-45 , 1 x USB
- Supported Windows 7 Features
- Windows HD Imaging
- TUV GS, ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 560 Watt
- Power Consumption Stand by / Sleep
- 9.2 Watt
- OS Required
- Limited warranty - 2 years
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 52 dBA
- 38.2 cm
- 39.4 cm
- 28.5 cm
- 16.2 kg
Kyocera FS-2020D Toner | In Stock | £99.64 |
