Kyocera FS-C8650DN A3 Colour Laser Printer
Quicklinx: C5Y3WS00 Mfr#: 1102MN3NL0
This top end high speed, high performance printer comes with a vast array of versatile features and options. It is able to print 50 A4 color ppm in the highest quality. It has Kyocera's long life technology meaning this machine will run and run. It also has our unique toner system that keeps costs and waste to a minimum, which is good for you and for the environment.
Kyocera FS-C8650DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
111 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Max Media Size (Custom)
304.8 mm x 1219 mm
Print Speed
Up to 27 ppm - B/W - A3 (297 x 420 mm) , Up to 25 ppm - colour - A3 (297 x 420 mm) , Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB, Gigabit LAN, USB host
PowerPC 750GL 750 MHz
RAM Installed (Max)
1 GB (2 GB)
Card Reader
Hard Drive
160 GB
Language Simulation
PostScript 3, PCL 6, PRESCRIBE IIe, XPS, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper, banners
Total Media Capacity
1150 sheets
Media Handling
2x 500-sheet input trays, 150-sheet multipurpose tray
Monthly Duty Cycle (max)
225000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
Microsoft Certification
Compatible with Windows 7
67.2 cm x 78.7 cm x 74.4 cm
Printer Type
Printer
Print Speed
Wired
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
4.9 sec
First Print Out Time Colour
6.2 sec
Language Simulation
Fonts Included
93 x scalable PCL , 136 x scalable PostScript , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
1 GB / 2 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
CompactFlash Card
Storage
Hard Drive
160 GB
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
304.8 mm x 1219 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 300 g/m²
1150 sheets
Media Feeders
2 x automatic - 500 sheets - ARCH B (304.8 x 457.2 mm) weight: 60 g/m² - 256 g/m² , 1 x automatic - 150 sheets - 304.8 x 1219.2 mm weight: 60 g/m² - 300 g/m²
Max Media Capacity
7650 sheets
Output Trays Capacity
750 sheets
Duty Cycle
225000 pages
Print server
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP
Expansion Slots
1 x expansion slot , Memory
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 15000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 10000 pages ISO/IEC 19798
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
1210 Watt
Power Consumption Stand by / Sleep
170 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
53 dBA
67.2 cm
78.7 cm
74.4 cm
111 kg
