The ECOSYS FS-C8520MFP A3 multifunction color printer offers all the benefits of a professional document management solution for workgroups and small offices. It features the Hybrid Platform for advanced solutions, easy-to-operate touchscreen and a range of paper-handling options, all in a well-designed compact package. Cost-efficient and eco-friendly offices will appreciate Kyocera's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
- Kyocera FS-C8520MFP - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 280 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology
- Power
- AC 230 V (50/60Hz)
- 59 cm x 59 cm x 74.8 cm
- 80 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty (Italy - 1 year)
- Laser - colour
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1.5 GB 1.5 GB
- Max Supported Memory
- 2 GB 2 GB
- Supported Flash Memory
- CompactFlash
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, auto tray switching, 4 on 1
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, KPDL3, PDF, XPS
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 14 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm)
- 600 sheets
- 1600 sheets
- 100 sheets
- 280 sheets
- Paper cassette - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , Bypass tray - 100 sheets - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 256 g/m² , ADF - 50 sheets - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 30 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Copying: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 40 ipm (A4) - colour , Printing: up to 10 ppm (A3) - B/W , Printing: up to 10 ppm (A3) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Operating System Support
- UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
- Voltage Required
- 557 Watt
- Power Consumption Standby
- 121 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 55 sec
- First Copy Out Time B/W
- 11.7 sec
- First Copy Out Time Colour
- 13.6 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- TUV GS, ISO 9001, ISO 14001
- ENERGY STAR Certified
- Limited warranty - 2 years , Italy: limited warranty - 1 year
- 59 cm
- 59 cm
- 74.8 cm
- 80 kg
- Sound Emission
- 35 dBA (idle) / 47 dBA (operating)
