The Kyocera FS-2100D can print at up to 40 pages per minute with a resolution of up to 1200dpi. Double sided printing is standard and 100 sheet multi-purpose tray and 500 sheet universal paper cassette are included. FS-2100D A4 mono laser printer also has a high capacity memory of 128MB of RAM to help it deal with complex print jobs that are sent to it. Printing direct from a USB stick is also included as standard with it's USB Port on the front of the Kyocera FS-2100D printer.
- Kyocera FS-2100D - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 13.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, USB host
- Processor
- PowerPC 465 500 MHz
- RAM Installed (Max)
- 128 MB (1.125 GB)
- Card Reader
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, IBM ProPrinter X24e, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 150000 pages
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
- 2-year warranty
- 38 cm x 41.6 cm x 28.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, USB host
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 128 MB / 1.125 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 150000 pages
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x direct print port - 4 pin USB Type A
- TUV, ISO 9001, GS, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 564 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years , Limited warranty - drum - 3 years or 300,000 pages
- Sound Emission (Idle)
- 29.5 dBA
- Sound Emission (Operating)
- 52.4 dBA
- 38 cm
- 41.6 cm
- 28.5 cm
- 13.5 kg
