Compact, efficient and highly economical, the FS-1061DN is the ideal printer for your desktop with a Quiet Mode button that significantly reduces noise. The standard duplex print capability and network interface make it perfect for a compact office or small workgroup. Robust and reliable, with KYOCERA's hard-wearing components, it is a hasslefree printer you can depend on.
- Kyocera FS-1061DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 6.7 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 25 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1800 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- Processor
- ARM 390 MHz
- RAM Installed (Max)
- 32 MB
- Media Type
- Plain paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Monthly Duty Cycle (max)
- 15000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8
- 35.8 cm x 27.6 cm x 24.1 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 1800 x 600 dpi
- First Print Out Time B/W
- 7.5 sec
- Printer Features
- Media Handling
- Processor
- ARM 390 MHz
RAM
- 32 MB
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 15000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
- TUV GS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 346 Watt
- Power Consumption Stand by
- 6 Watt
- Power Consumption Sleep
- 3 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Sound Emission (Idle)
- 29 dBA
- Sound Emission (Operating)
- 51.2 dBA
- Sound Emission (Quiet Mode)
- 49.6 dBA
- 35.8 cm
- 27.6 cm
- 24.1 cm
- 6.7 kg
