Kyocera FS-1061DN Mono Laser Printer
Quicklinx: 8JSSWS00 Mfr#: 1102M33NL0
£164.68 ex VAT
£197.61 inc VAT
Compact, efficient and highly economical, the FS-1061DN is the ideal printer for your desktop with a Quiet Mode button that significantly reduces noise. The standard duplex print capability and network interface make it perfect for a compact office or small workgroup. Robust and reliable, with KYOCERA's hard-wearing components, it is a hasslefree printer you can depend on.
Kyocera FS-1061DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
6.7 kg
Max Media Size
Legal (216 x 356 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 25 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1800 x 600 dpi
Image Enhancement Technology
1200 dpi quality / KIR2
Automatic Duplexing
USB 2.0, LAN
390 MHz
RAM Installed (Max)
32 MB
Media Type
Plain paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Monthly Duty Cycle (max)
15000 impressions
Print server
Apple MacOS X, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8
1-year warranty
35.8 cm x 27.6 cm x 24.1 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0, LAN
1800 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
7.5 sec
Media Handling
390 MHz
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Plain paper
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
15000 impressions
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
TUV GS
Power supply - internal
Frequency Required
50/60 Hz
346 Watt
Power Consumption Stand by / Sleep
6 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
35.8 cm
27.6 cm
24.1 cm
6.7 kg
