- Up to 20 pages per minute in A4
- 250-sheet universal cassette
- 1,200 dpi quality (1,800 x 600)
- Very compact size and footprint
- Low-noise printing, with Quiet Mode function
- Highly reliable thanks to long-life components
- Exceptionally low printing costs in its class
Compact, efficient and highly economical, the FS-1041 is the ideal printer for your desktop with a Quiet Mode button that significantly reduces noise.
It is also fast, printing the first page in just 8.5 seconds after sending the job. Robust and reliable, with KYOCERA's hardwearing components, it is a hassle-free device you can depend on.
- Kyocera FS-1041 - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 6.3 kg
- Max Media Size
- Legal (216 x 356 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 20 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1800 x 600 dpi
- Image Enhancement Technology
- 1200 dpi quality / KIR2
- Interface
- USB 2.0
- Processor
- 390 MHz
- RAM Installed (Max)
- 32 MB
- Media Type
- Plain paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray
- Monthly Duty Cycle (max)
- 10000 impressions
- System Requirements
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8
- 35.8 cm x 26.2 cm x 24.1 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 1800 x 600 dpi
- First Print Out Time B/W
- 8.5 sec
- Media Handling
- Processor
- 390 MHz
RAM
- 32 MB
Media Handling
- Media Type
- Plain paper
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 10000 impressions
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752
- TUV GS
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 304 Watt
- Power Consumption Stand by / Sleep
- 5 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 35.8 cm
- 26.2 cm
- 24.1 cm
- 6.3 kg
