Kyocera FS-1041 Mono Laser Printer
Quicklinx: 8JSRWS00 Mfr#: 1102M23NL0
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£52.26 ex VAT
£62.71 inc VAT
  • Up to 20 pages per minute in A4
  • 250-sheet universal cassette
  • 1,200 dpi quality (1,800 x 600)
  • Very compact size and footprint
  • Low-noise printing, with Quiet Mode function
  • Highly reliable thanks to long-life components
  • Exceptionally low printing costs in its class
Compact, efficient and highly economical, the FS-1041 is the ideal printer for your desktop with a Quiet Mode button that significantly reduces noise.
It is also fast, printing the first page in just 8.5 seconds after sending the job. Robust and reliable, with KYOCERA's hardwearing components, it is a hassle-free device you can depend on.
Kyocera FS-1041 - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
6.3 kg
Max Media Size
Legal (216 x 356 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1800 x 600 dpi
Image Enhancement Technology
1200 dpi quality / KIR2
USB 2.0
390 MHz
RAM Installed (Max)
32 MB
Media Type
Plain paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray
Monthly Duty Cycle (max)
10000 impressions
AC 230V
Apple MacOS X, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8
35.8 cm x 26.2 cm x 24.1 cm
Printer Type
Printer
Print Speed
Wired
USB 2.0
1800 x 600 dpi
First Print Out Time B/W
8.5 sec
Media Handling
390 MHz
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Plain paper
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
10000 impressions
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752
TUV GS
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
304 Watt
Power Consumption Stand by / Sleep
5 Watt
Environmental Standards
ENERGY STAR
35.8 cm
26.2 cm
24.1 cm
6.3 kg
Type: Printer
Technology: Laser
Max Print Speed: 20ppm
Brand: Kyocera
Price Range Ex VAT: 50 - 100
