Kyocera FS-1041 Mono Laser Printer
Quicklinx: 8JSRWS00 Mfr#: 1102M23NL0
  • Up to 20 pages per minute in A4
  • 250-sheet universal cassette
  • 1,200 dpi quality (1,800 x 600)
  • Very compact size and footprint
  • Low-noise printing, with Quiet Mode function
  • Highly reliable thanks to long-life components
  • Exceptionally low printing costs in its class
Compact, efficient and highly economical, the FS-1041 is the ideal printer for your desktop with a Quiet Mode button that significantly reduces noise.
It is also fast, printing the first page in just 8.5 seconds after sending the job. Robust and reliable, with KYOCERA's hardwearing components, it is a hassle-free device you can depend on.
  • Efficient connectivity
    Equipped with USB 2.0 interface, this printer offers seamless connection to your devices, ensuring a smooth and reliable printing experience.
  • High-quality printing
    With a maximum resolution of 1800 x 600 DPI, the Kyocera FS 1041 delivers sharp, clear monochrome prints, making it suitable for professional documents.
  • Eco-friendly operation
    Certified by ENERGY STAR, the printer operates efficiently, reducing power consumption and contributing to a greener environment.
  • Robust media handling
    Supports a wide range of media sizes up to Legal (216 x 356 mm) and weights from 60 to 220 g/m2, accommodating various printing needs with a 250-sheet input tray.
  • Fast first print
    Achieves the first print out in just 8.5 seconds, ensuring quick access to your documents when you need them.
Kyocera FS-1041 - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
6.3 kg
Max Media Size
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1800 x 600 dpi
Image Enhancement Technology
1200 dpi quality / KIR2
USB 2.0
390 MHz
RAM Installed (Max)
32 MB
Media Type
Plain paper
Total Media Capacity
250 sheets
Media Handling
Monthly Duty Cycle (max)
10000 impressions
Apple MacOS X, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8
35.8 cm x 26.2 cm x 24.1 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0
1800 x 600 dpi
First Print Out Time B/W
8.5 sec
Media Handling
390 MHz
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Plain paper
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
10000 impressions
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752
TUV GS
Power supply - internal
Frequency Required
50/60 Hz
304 Watt
Power Consumption Stand by / Sleep
5 Watt
Environmental Standards
ENERGY STAR
35.8 cm
26.2 cm
24.1 cm
6.3 kg
8JSR Kyocera TK-1115 TONER FOR FS-1041/1220/1320 1.6K In Stock £59.24
