Kyocera ECOSYS P6035cdn A4 Colour Laser Printer
Quicklinx: BP12WS00 Mfr#: 1102NS3NL0
Highly productive and economical, the ECOSYS P6035cdn combines speed and excellent color quality with intelligent network and security features - meeting the demands of busy offices and work groups of nearly all sizes. And thanks to cost-effective ECOSYS technology with its long-life components, this device offers great potential for cost savings.
Kyocera ECOSYS P6035cdn in More Detail
Designed to provide highly economical and productive support in small and medium offices, the ECOSYS P6035cdn from Kyocera combines quick print speeds with high quality output. The ECOSYS has been developed to minimise the costs of printing without ever compromising the vibrancy and tones of the print.
The multibit technology of the printer benefits from 9,600dpi printing.
Incredible Print Speeds
Powered by a 1 GHz CPU, the ECOSYS P6035cdn is capable of printing upwards of 35 pages per minute in colour or black and white. The first print speed on 6.5 seconds in black and white, and 7.5 seconds in colour lends the printer perfectly to environments which demand minimal downtime and require instant action.
The five built-in paper trays effortlessly accommodate an input/output capacity of 500 sheets. The lifelong components of the printer also ensure cost-effective maintenance in the short-term and the long-term – increasing the potential for savings.
Mobile Printing
The modest-looking ECOSYS P6035cdn also offers a range of connectivity options including mobile printing with Mopria and Kyocera Mobile Print. The machine also benefits from AirPrint – perfect for office environments which use a selection of Apple devices including iPads, iPhones and more. This can help simplify the process of printing direct from source rather than necessitating the task of sharing files and documents with a dedicated printer-connected computer.
Kyocera ECOSYS P6035cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
29 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 465S 1 GHz
RAM Installed (Max)
512 MB (2 GB)
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
1-year warranty
39 cm x 53.2 cm x 46.95 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.5 sec
First Print Out Time Colour
7.5 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
PowerPC 465S 1 GHz
RAM
RAM Installed (Max)
512 MB / 2 GB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
500 sheets
Duty Cycle
100000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 5000 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 5000 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 5000 pages ISO/IEC 19752
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
523 Watt
Power Consumption Sleep
2.1 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Operating)
51.2 dBA
Sound Emission (Quiet Mode)
48.2 dBA
39 cm
53.2 cm
46.95 cm
29 kg
BP12 Kyocera Black Ton Ecos M6035Cidn M6535 P6035 12K (TK 5150K) In Stock £116.57
