Highly productive and economical, the ECOSYS P6035cdn combines speed and excellent color quality with intelligent network and security features - meeting the demands of busy offices and work groups of nearly all sizes. And thanks to cost-effective ECOSYS technology with its long-life components, this device offers great potential for cost savings.
Kyocera ECOSYS P6035cdn in More Detail
Designed to provide highly economical and productive support in small and medium offices, the ECOSYS P6035cdn from Kyocera combines quick print speeds with high quality output. The ECOSYS has been developed to minimise the costs of printing without ever compromising the vibrancy and tones of the print.
The multibit technology of the printer benefits from 9,600dpi printing.
Incredible Print Speeds
Powered by a 1 GHz CPU, the ECOSYS P6035cdn is capable of printing upwards of 35 pages per minute in colour or black and white. The first print speed on 6.5 seconds in black and white, and 7.5 seconds in colour lends the printer perfectly to environments which demand minimal downtime and require instant action.
The five built-in paper trays effortlessly accommodate an input/output capacity of 500 sheets. The lifelong components of the printer also ensure cost-effective maintenance in the short-term and the long-term – increasing the potential for savings.
Mobile Printing
The modest-looking ECOSYS P6035cdn also offers a range of connectivity options including mobile printing with Mopria and Kyocera Mobile Print. The machine also benefits from AirPrint – perfect for office environments which use a selection of Apple devices including iPads, iPhones and more. This can help simplify the process of printing direct from source rather than necessitating the task of sharing files and documents with a dedicated printer-connected computer.
- Kyocera ECOSYS P6035cdn - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 29 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- PowerPC 465S 1 GHz
- RAM Installed (Max)
- 512 MB (2 GB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
- 1-year warranty
- 39 cm x 53.2 cm x 46.95 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- First Print Out Time Colour
- 7.5 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB / 2 GB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS, IPPS
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752 , 1 x toner cartridge (yellow) - up to 5000 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 5000 pages ISO/IEC 19752 , 1 x toner cartridge (magenta) - up to 5000 pages ISO/IEC 19752
- TUV, ISO 9001, GS, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 523 Watt
- Power Consumption Sleep
- 2.1 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Operating)
- 51.2 dBA
- Sound Emission (Quiet Mode)
- 48.2 dBA
- 39 cm
- 53.2 cm
- 46.95 cm
- 29 kg
Kyocera Black Ton Ecos M6035Cidn M6535 P6035 12K (TK 5150K) | In Stock | £116.57 |
