Kyocera ECOSYS P6021cdn Colour Laser Printer
MOBILE PRINTING SUPPORT, INCLUDING AIRPRINT
Quicklinx: 98JNWS00 Mfr#: 1102PS3NL0
Providing small teams and demanding users with high-quality color prints. The ECOSYS P6021cdn is a compact device with low noise output, which makes it the ideal business companion for any office. It has an integrated duplex unit as standard for effortless double sided printing. It combined with improved energy efficiency: these features help you reduce the impact of your printing activities on the environment. Its long life components reduce waste and make this printer the reliable business companion of choice!
  • ECOSYS
    ECOSYS stands for ECOlogy, ECOnomy and SYStem printing. With their long-life components, ECOSYS devices are designed to maximize durability and minimize the total cost of ownership with regard to maintenance, administration and consumables. The cartridge-free system means that the toner is the only consumable and hardly ever needs to be replaced. The modular design concept allows you to add workflow-enhancing functions as required and the integrated system soft ware provides long-term cross-network compatibility.
  • Prescribe IIc
    With the Kyocera page design and control language Prescribe IIc, even complex graphics, logos and forms (multipart forms) can be created independently on the system and saved and updated in the printer. Consequently, an integration of graphics into print files is no longer necessary. The printer accesses them as required and thereby reduces network traffic.
  • Kyocera NetViewer
    Koycera NetViewer enables the complete monitoring and control of all ECOSYS printers and digital Kyocera multifunctional from any Windows. PC and thus gives you the means to streamline your network administration. It also supports standardized SNMP.
  • Command center RX
    The Command Cener RX enables to control and manage various settings by accessing the device via a common web browser. It automatically updates screens, customizes user screens, and displays department and restriction settings.
  • USB interface for USB flash memory device
    Documents can be printed directly from a USB flash memory device via the USB host interface. You can select documents stored as PDF, XPS, TIFF or JPEG directly on the printer's control panel. No computer is required.
  • Application-based profiles
    The KX printer driver can create a direct link between dedicated applications and predefined or customized print profiles. You can set that all documents from a user or an application be printed in black and white with activated duplex mode as standard, thus leading to a reduced toner and paper consumption.
Kyocera ECOSYS P6021cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
29.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 465S 667 MHz
RAM Installed (Max)
512 MB (1.5 GB)
Card Reader
Language Simulation
PCL 5C, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
1000 - 1667 pages
Print server
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
Environmental Standards
EPEAT Silver
39 cm x 52.3 cm x 37 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
10.5 sec
First Print Out Time Colour
12 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
512 MB / 1.5 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - 216 x 297 mm weight: 60 g/m² - 163 g/m²
Max Media Capacity
1300 sheets
Output Trays Capacity
250 sheets
Duty Cycle
50000 pages
1000 - 1667 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1200 pages , 1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
Frequency Required
50/60 Hz
353 Watt
Power Consumption Stand by
61 Watt
Power Consumption Sleep
4 Watt
EPEAT Compliant
EPEAT Silver
ENERGY STAR
Sound Emission (Operating)
48.2 dBA
39 cm
52.3 cm
37 cm
29.3 kg
