Kyocera ECOSYS P5021cdn A4 Colour Laser Printer
Quicklinx: CHK3WS00 Mfr#: 1102RF3NL0
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
22 in stock
£134.46 ex VAT
£161.35 inc VAT
The ECOSYS P5021CDN entry-level A4 color printer offers more than you could ask for. Despite its compact design, this economical color device includes plenty of valuable functions and achieves professional results with a resolution of 1200 dpi. Features such as the duplex unit for double-sided printing or the direct printing functions (via USB host) keep your work running seamlessly. This reliable device is the perfect solution for small offices that set high standards.
  • Up to 21 A4 pages per minute in colour and black and white
  • Up to 9,600 dpi printing quality with multibit technology
  • Standard duplex printing
  • Mobile printing support including AirPrint
  • Up to 4 paper feeders for flexible media support
  • Direct printing from USB flash memory
  • Low-noise printing, no noise in sleep mode
Providing small teams and demanding users with high-quality colour prints. The ECOSYS P6021cdn is a compact device with low noise output, which makes it the ideal business companion for any offi ce. It has an integrated duplex unit as standard for eff ortless double sided printing. Combined with improved energy efficiency: these features help you reduce the impact of your printing activities on the environment. Its long life components reduce waste and make this printer the reliable business companion of choice!
Toner Change:
Unboxing:
Kyocera ECOSYS P5021cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 21 ppm - B/W - A4 (210 x 297 mm) , Up to 21 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
800 MHz
RAM Installed (Max)
512 MB (512 MB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, XPS
Barcodes
PDF417, EAN-128, EAN-8, EAN-13
Media Type
Plain paper
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Print server
Printer Features
Toner Save mode support
AC 240 V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
41 cm x 41 cm x 32.9 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
11 sec
First Print Out Time Colour
12.5 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
Media Thickness Range
Up to 0.11 mm
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
550 sheets
Output Trays Capacity
150 sheets
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1200 pages ISO/IEC 19752 , 1 x toner cartridge (cyan) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1200 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1200 pages ISO/IEC 19798
ISO 9001, ISO 14001, AS/NZS 3260
Power supply - internal
AC 240 V
Frequency Required
50 Hz
345 Watt
Power Consumption Stand by
33 Watt
Power Consumption Sleep
0.9 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
48 dBA
41 cm
41 cm
32.9 cm
21 kg
Type: Printer
Output Type: Colour
Technology: Laser
Max Print Speed: 21ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: 100 - 150
