Kyocera ECOSYS P4040DN A3 Mono Laser Printer 40ppm 1200 x 1200 dpi
Quicklinx: C4MGWS00 Mfr#: 1102P73NL0
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
Hurry, only 1 left in stock!
£900.10 ex VAT
£1,080.12 inc VAT
A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.
Kyocera ECOSYS P4040dn - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
20 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
297 mm x 450 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 22 ppm - B/W - A3 (297 x 420 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
PowerPC 465 750 MHz
RAM Installed (Max)
256 MB (1.25 GB)
Language Simulation
PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, XPS, EPSON LQ 850, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
20000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
AC 230V
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
1-year warranty
46.9 cm x 41 cm x 32 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7.5 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
PowerPC 465 750 MHz
RAM
RAM Installed (Max)
256 MB / 1.25 GB (max)
Media Handling
Media Type
Plain paper
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
70 mm x 148 mm
297 mm x 450 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Duty Cycle
150000 pages
20000 pages
Print server
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 7500 pages ISO/IEC 19752
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
586 Watt
Power Consumption Sleep
1.5 Watt
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
50.4 dBA
Sound Emission (Quiet Mode)
49.6 dBA
46.9 cm
41 cm
32 cm
20 kg
Type: Printer
Technology: Laser
Max Print Speed: 22ppm
Max Paper Size: A3 (297 x 420 mm)
Brand: Kyocera
Price Range Ex VAT: 750 - 1000
