With up to 50 pages per minute print speed, fast first print times, a powerful controller, mobile print support and low running costs, the ECOSYS P3050dn will be a welcome addition to any team. It also boasts enhanced security features with card authentication, private print and hard disk protection. And as you would expect of a KYOCERA printer, the long-life components and lower energy consumption ensure this device leaves a small environmental footprint.
- Kyocera ECOSYS P3150dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 15.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 140 mm
- Max Media Size (Custom)
- 216 mm x 915 mm
- Print Speed
- Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 35.5 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 74 ppm - B/W - A5 (148 x 210 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Processor
- ARM Cortex-A9 1.2 GHz
- RAM Installed (Max)
- 512 MB (2560 MB)
- Language Simulation
- PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, XPS, EPSON LQ 850, TIFF, JPEG, PDF Direct
- Media Type
- Plain paper, banner paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology, Mopria certified
- Power
- AC 220/240 V
- 38 cm x 41 cm x 32 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- 5-line backlit LCD display
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 5.4 sec
- Fonts Included
- 93 x outline , 1 x bitmapped , 45 x barcode
- Printer Features
- Media Handling
- Processor
RAM
- 512 MB / 2560 MB (max)
Card Reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 140 mm
- 216 mm x 915 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 500 sheets
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, IPP
- SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 8000 pages ISO/IEC 19752
- TUV GS, ISO 9001, ISO 14001
- Power Device
- Power supply - internal
- Voltage Required
- AC 220/240 V
- Frequency Required
- 50/60 Hz
- 636 Watt
- Power Consumption Stand by
- 11 Watt
- Power Consumption Sleep
- 0.5 Watt
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 54.5 dBA
- 38 cm
- 41 cm
- 32 cm
- 15.5 kg
Ink (2)
Kyocera TK-3170 Black Toner Cassette | In Stock | £81.79 |
Kyocera TK 3170 Black Toner Kit for ECOSYS P3050dn | In Stock | £76.84 |
Other bundles (1)
Kyocera Group D 3 year Total Support On-site Next day | In Stock | £217.40 |
