When the going gets tough, you need a printer that exceeds all expectations to help you meet your deadline and the ECOSYS P3055dn does exactly that. With a print speed of up to 55 pages per minute, a fast time to first print and superior 1200 dpi resolution, it satisfies even the most demanding of workgroups. The device has enhanced security features and flexible paper handling options, with a maximum paper capacity of 2,600 sheets. It’s long-life components mean incredibly low running costs and low impact on the environment.
- Up to 55 pages per minute A4 and A5
- Time to first print: only 6.6 seconds
- Standard Gigabit LAN, Wi-Fi option with Wi-Fi Direct available
- Mobile Printing support for AirPrint, Mopria, KYOCERA Mobile Print
- Double-sided and N-up printing for less paper consumption
- Up to 6 paper trays for superior flexibility and high capacity
- Optimal document distribution and workflow with optional Print&FollowTM*
- Advanced document handling with optional SD cards
- Environmentally friendly: long-life components, low energy consumption
- Exceptionally-low printing costs in its class
Finding the Serial Number:
Toner Change:
Unboxing:
- Kyocera ECOSYS P3055DN - printer - monochrome - laser
- Printer Type
- Workgroup printer - laser - monochrome
- 15.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 55 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (2.5 GB)
- Language Simulation
- PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 250000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- Power
- AC 230V
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
- 1-year warranty
- 39.6 cm x 42.1 cm x 34.2 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.6 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 2.5 GB (max)
Card Reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 250000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS, IPPS
- Secure Print, SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752
- TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50 Hz
- 675 Watt
- Power Consumption Stand by
- 11 Watt
- Power Consumption Sleep
- 0.9 Watt
- Software Included
- Google Cloud Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year , Limited warranty - drum - 3 years or 500,000 pages
- Sound Emission (Idle)
- 27.1 dBA
- Sound Emission (Operating)
- 54.7 dBA
- Sound Emission (Quiet Mode)
- 50.4 dBA
- 39.6 cm
- 42.1 cm
- 34.2 cm
- 15.5 kg
