Kyocera ECOSYS P3055dn A4 Mono Laser Printer
Quicklinx: CKF2WS00 Mfr#: 1102T73NL0
When the going gets tough, you need a printer that exceeds all expectations to help you meet your deadline and the ECOSYS P3055dn does exactly that. With a print speed of up to 55 pages per minute, a fast time to first print and superior 1200 dpi resolution, it satisfies even the most demanding of workgroups. The device has enhanced security features and flexible paper handling options, with a maximum paper capacity of 2,600 sheets. It’s long-life components mean incredibly low running costs and low impact on the environment.
  • Up to 55 pages per minute A4 and A5
  • Time to first print: only 6.6 seconds
  • Standard Gigabit LAN, Wi-Fi option with Wi-Fi Direct available
  • Mobile Printing support for AirPrint, Mopria, KYOCERA Mobile Print
  • Double-sided and N-up printing for less paper consumption
  • Up to 6 paper trays for superior flexibility and high capacity
  • Optimal document distribution and workflow with optional Print&FollowTM*
  • Advanced document handling with optional SD cards
  • Environmentally friendly: long-life components, low energy consumption
  • Exceptionally-low printing costs in its class
Finding the Serial Number:
Toner Change:
Unboxing:
Kyocera ECOSYS P3055DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
15.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 55 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
1.2 GHz
RAM Installed (Max)
512 MB (2.5 GB)
Language Simulation
PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Monthly Duty Cycle (max)
250000 pages
Print server
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
1-year warranty
39.6 cm x 42.1 cm x 34.2 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.6 sec
Language Simulation
Fonts Included
93 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 2.5 GB (max)
Card Reader
Supported Flash Memory Cards
SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Duty Cycle
250000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
Secure Print, SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 10000 pages ISO/IEC 19752
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
Power supply - internal
Frequency Required
50 Hz
675 Watt
Power Consumption Stand by
11 Watt
Power Consumption Sleep
0.9 Watt
Software Included
Google Cloud Print
Environmental Standards
ENERGY STAR
Limited warranty - 1 year , Limited warranty - drum - 3 years or 500,000 pages
Sound Emission (Idle)
27.1 dBA
Sound Emission (Operating)
54.7 dBA
Sound Emission (Quiet Mode)
50.4 dBA
39.6 cm
42.1 cm
34.2 cm
15.5 kg
