With up to 50 pages per minute print speed, fast first print times, a powerful controller, mobile print support and low running costs, the ECOSYS P3050dn will be a welcome addition to any team. It also boasts enhanced security features with card authentication, private print and hard disk protection. And as you would expect of a KYOCERA printer, the long-life components and lower energy consumption ensure this device leaves a small environmental footprint.
- Up to 50 pages per minute A4 and A5
- Time to first print: only 6.2 seconds
- Standard Gigabit LAN, Wi-Fi option with Wi-Fi Direct available
- Powerful 1.2 GHz CPU and 512 MB controller
- Mobile Printing support for AirPrint, Mopria, KYOCERA Mobile Print
- Double-sided and N-up printing for less paper consumption
- 500 sheet paper output capacity for continuous printing
- Optimal document distribution and workflow with optional Print&FollowTM*
- Environmentally friendly: long-life components, low energy consumption
- Exceptionally-low printing costs in its class
Finding the Serial Number:
Toner Change:
Unboxing:
Efficient productivity
With a first print out time of just 6.2 seconds and a monthly duty cycle range exceeding 100,000 pages, this printer is designed to handle high-volume printing with ease, ensuring your office's productivity remains high. -
Advanced connectivity
Equipped with Gigabit Ethernet, USB 2.0, and USB host interfaces alongside Mopria Print Service for mobile printing capabilities, this printer offers versatile connectivity options to easily integrate into any modern office environment. -
Robust media handling
Supporting a wide range of media sizes up to Legal (216 x 356 mm) and weights between 60 g/m2 and 220 g/m2, this printer is capable of handling diverse printing needs, from standard documents to more demanding printing tasks. -
High-capacity printing
With a maximum media capacity of 2600 sheets and automatic duplexing feature, the Kyocera ECOSYS P3050DN is built to deliver large print jobs efficiently, reducing the need for frequent paper refills and supporting eco-friendly office practices. -
Secure and reliable
Featuring advanced security protocols including IPsec and SSL, along with HTTPS and SNMP 3 for remote management, this printer ensures your documents remain secure throughout the printing process, making it a trustworthy choice for sensitive information.
- Kyocera ECOSYS P3050DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 15.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 50 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (2.5 GB)
- Language Simulation
- PCL 5C, PostScript 3, IBM X24E, PCL 6, PCL XL, KPDL3, PRESCRIBE IIe, XPS, EPSON LQ 850, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 600 sheets
- Media Handling
- 100-sheet multipurpose tray, 500-sheet input tray
- Monthly Duty Cycle (max)
- 200000 pages
- Networking
- Print server
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.8 or later
- 1-year warranty (Germany - 2 years)
- 39.6 cm x 42.1 cm x 34.2 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.2 sec
- Fonts Included
- 93 x scalable , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 2.5 GB (max)
Card Reader
- Supported Flash Memory Cards
- SDHC Memory Card
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 100 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 200000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 3, HTTPS, IPPS
- Secure Print, SSL, IPsec
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 8000 pages ISO/IEC 19752
- TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50 Hz
- 636 Watt
- Power Consumption Stand by
- 11 Watt
- Power Consumption Sleep
- 0.9 Watt
- Software Included
- Google Cloud Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year , Limited warranty - drum - 3 years or 500,000 pages
- Regional Warranty Exceptions
- Germany - 2 years
- Sound Emission (Idle)
- 26.9 dBA
- Sound Emission (Operating)
- 53.2 dBA
- Sound Emission (Quiet Mode)
- 50.8 dBA
- 39.6 cm
- 42.1 cm
- 34.2 cm
- 15.5 kg
Kyocera TK 3160 Black Toner Kit for ECOSYS P3045dn | In Stock | £76.72 |
