Kyocera ECOSYS P2235dw A4 Mono Laser Printer
Quicklinx: CKDRWS00 Mfr#: 1102RW3NL0
Type: Printer
Functionality: Printer
Wireless Capability: Wireless, Wired
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
£220.17 ex VAT
£264.20 inc VAT
A productive solution for workgroups that require a wide variety of output sizes from A6 up to A3. This fast and compact printer offers an expandable paper capacity of up to 6 paper trays for flexible paper handling. Plus this team-player knows exactly how to impress with comprehensive security features and ECOSYS long-life technology that gives you exceptionally low cost per page and less waste.
  • USB host interface
    Documents can be printed directly from a USB flash memory via the USB host interface. The documents stored as PDF, XPS, TIFF or JPEG are selected directly via the printer's control panel. No computer is required.
  • Application-based profiles
    The printer driver can create a direct link between dedicated applications and predefined or customized print profiles. You can set that all documents from a user or an application be printed with activated duplex mode as standard, thus leading to a reduced paper consumption.
Kyocera ECOSYS P2235dw - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
14 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 35 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host, Wi-Fi
800 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5E, PostScript 3, PCL 6, PCL XL, KPDL3, PDF, PRESCRIBE IIe, XPS
Barcodes
PDF417
Media Type
Plain paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Print server
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
37.5 cm x 39.3 cm x 27.2 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
6.8 sec
Language Simulation
Fonts Included
93 x scalable , 45 x barcode
Barcodes
PDF417
Printer Features
Media Handling
800 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Card Reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
Media Weight
60 g/m² - 220 g/m²
350 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
Max Media Capacity
850 sheets
Output Trays Capacity
250 sheets
Print server
Remote Management Protocol
SNMP 3, HTTPS, IPPS
Security Protocols & Features
SSL, IPsec
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
TUV, ISO 9001, GS, ISO 14001, ISO 7779
Power supply - internal
Frequency Required
50/60 Hz
620 Watt
Power Consumption Stand by
8 Watt
Power Consumption Sleep
0.8 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
47.9 dBA
37.5 cm
39.3 cm
27.2 cm
14 kg
CKDR Kyocera TK 1150 Black Original Toner Cartridge In Stock £58.60
Type: Printer
Wireless Capability: Wired
Brand: Kyocera
