A reliable and robust office solution for perfect black/white printing day in, day out! The ECOSYS P2035d desktop printer is very compact and its standard duplex printing functionality helps you reduce your paper consumption. You can also regulate its noise level according to your needs. It has long life components that reduce downtime and large paper cassettes holding up to 550 sheets. It will carry out daily office tasks without hassle or noise. This printer is a perfect companion for busy days: discreet, hardworking and reliable!
- Kyocera ECOSYS P2035d - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 12 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 70 mm x 148 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0
- Processor
- PowerPC 405F5 360 MHz
- RAM Installed (Max)
- 32 MB (544 MB)
- Language Simulation
- PCL 5E, PCL 6, Diablo 630, KPDL3, PRESCRIBE IIe, EPSON LQ 850, IBM ProPrinter X24e
- Barcodes
- PDF417
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 2000 pages
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.5 or later
- 2-year warranty (France - 1 year)
- 37.5 cm x 39.3 cm x 25 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6 sec
- Barcodes
- PDF417
- Printer Features
- Media Handling
- Processor
RAM
- 32 MB / 544 MB (max)
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 70 mm x 148 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Oficio (216 x 343 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 250 sheets - 216 x 297 mm weight: 60 g/m² - 120 g/m²
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 20000 pages
- 2000 pages
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19752
- TUV, ISO 9001, GS, ISO 14001, ISO 7779
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 535 Watt
- Power Consumption Stand by
- 7.1 Watt
- Power Consumption Sleep
- 2.6 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years , France: limited warranty - 1 year
- Sound Emission (Idle)
- 30.7 dBA
- Sound Emission (Operating)
- 53.3 dBA
- Sound Emission (Quiet Mode)
- 49.6 dBA
- 37.5 cm
- 39.3 cm
- 25 cm
- 12 kg
