Kyocera ECOSYS M6526CDN Colour Multifunction Printer
Quicklinx: BKRKWS00 Mfr#: 1102PW3NL0
The unbeatable high performers in color and black and white. These highly productive multifunctional printers quickly deal with your office workload: they combine fast print speeds together with a short time for the first print and copy. They also offer the facility to scan both color and black and white documents to file thanks to their high-performance scanning processors. The exceptional reliability of Kyocera's renowned long-life components ensure low running costs and reduced impact on the environment. What's more, their full duplex scan, print and copy functionality makes them the ideal partner for work groups that want to maximize productivity whilst minimizing waste.
Kyocera ECOSYS M6526cdn - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
10000 pages
Max Copying Speed
Up to 26 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 dpi
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
1300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail
AC 230 V (50/60Hz)
51.4 cm x 55 cm x 58 cm
36.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
EPEAT Silver, ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
10000 pages
Display
5 lines
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
2 GB
Supported Flash Memory
SD Memory Card, USB flash drive, SDHC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Sort, Multiple Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Total Memory Capacity
Up to 200 pages
Fax Machine Features
Speed Dialing
22 station(s)
Broadcast Transmission
Double Sided Faxing, delayed sending, fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 70 x 148 mm
300 sheets
Max Media Capacity
1300 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 26 ppm (A4) - B/W , Printing: up to 26 ppm (A4) - colour , Copying: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - colour , Scanning: up to 35 ppm - B/W , Scanning: up to 25 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, 802.1x
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.0 - 10.9
AC 230 V (50/60Hz)
445 Watt
Power Consumption Standby
39 Watt
Power Consumption Sleep
3 Watt
Warm-Up Time
29 sec
First Copy Out Time B/W
10 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 2500 pages , 1 x toner cartridge (magenta) - up to 2500 pages , 1 x toner cartridge (yellow) - up to 2500 pages
TUV, ISO 9001, GS, ISO 14001
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
51.4 cm
55 cm
58 cm
36.5 kg
Sound Emission
29.2 dBA (idle) / 48.7 dBA (operating)
