The unbeatable high performers in color and black and white. These highly productive multifunctional printers quickly deal with your office workload: they combine fast print speeds together with a short time for the first print and copy. They also offer the facility to scan both color and black and white documents to file thanks to their high-performance scanning processors. The exceptional reliability of Kyocera's renowned long-life components ensure low running costs and reduced impact on the environment. What's more, their full duplex scan, print and copy functionality makes them the ideal partner for work groups that want to maximize productivity whilst minimizing waste.
- Kyocera ECOSYS M6526cdn - multifunction printer (colour)
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 10000 pages
- Max Copying Speed
- Up to 26 ppm (mono) / up to 26 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Scanning
- 600 dpi
- Original Size
- Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 1300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 51.4 cm x 55 cm x 58 cm
- 36.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, EPEAT Silver
- Fax Type
- Plain paper
- Laser - colour
- 10000 pages
- Display
- 5 lines
- Interface
- AirPrint Enabled
- Standard Memory
- 1024 MB
- Max Supported Memory
- 2048 MB
- Supported Flash Memory
- SD Memory Card, USB flash drive, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy, Sort, Multiple Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, KPDL3, PCL XL, PDF, XPS
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Optical Resolution
- 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Total Memory Capacity
- Up to 200 pages
Fax Machine Features
- Speed Dialing
- 22 station(s)
- Broadcast Transmission
- Double Sided Faxing, delayed sending, fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 70 x 148 mm
- 300 sheets
- 1300 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - B/W , Printing: up to 26 ppm (A4) - colour , Copying: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - colour , Scanning: up to 35 ppm - B/W , Scanning: up to 25 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec, 802.1x
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.0 - 10.9
- Voltage Required
- 445 Watt
- Power Consumption Standby
- 39 Watt
- Power Consumption Sleep
- 3 Watt
- Warm-Up Time
- 29 sec
- First Copy Out Time B/W
- 10 sec
- First Copy Out Time Colour
- 12 sec
- Consumables Included
- 1 x Cartridge (black) - up to 2500 pages , 1 x Cartridge (cyan) - up to 2500 pages , 1 x Cartridge (magenta) - up to 2500 pages , 1 x Cartridge (yellow) - up to 2500 pages
- TUV, ISO 9001, GS, ISO 14001
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 51.4 cm
- 55 cm
- 58 cm
- 36.5 kg
- Sound Emission
- 29.2 dBA (idle) / 48.7 dBA (operating)
