Kyocera ECOSYS M5526cdw A4 Colour Laser Multifunction
Quicklinx: CHKJWS00 Mfr#: 1102R73NL0
Functionality: Copier, Printer, Fax, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
£365.47 ex VAT
£438.56 inc VAT
The compact ECOSYS M5526cdw offers exceptional four-in-one convenience and unmatched economy as a versatile desktop color printer, copier, scanner and monochrome fax. Designed to support the demands of today’s mobile workforce, the network-/wireless-ready ECOSYS M5526cdw delivers professional color and crisp black-and-white output at up to 27 pages per minute. And with intuitive walk-up operation and software tools, this flexible system enables users to create, access, store and share information faster than ever before–whether in the office or on the go.
  • Up to 26 pages per minute in A4 in colour and black and white
  • 1,200 dpi printing quality
  • 4,3 inch touch screen for easy operation
  • Dual scan document processor
  • Wireless support including AirPrint, Mopria, KYOCERA Mobile Print
  • Direct printing from and scanning to USB flash memory
  • High security through SSL, IPsec and Private Print functionality
  • Double-sided print, copy, scan and fax functionality as standard
  • Compact design with low-noise printing
  • Exceptionally low printing costs in its class
This top of the range device combines the best colour quality with low running costs. It simplifies your workflow with ease thanks to its dual scan document processor, 4.3 inch touch screen and multiple program keys. Not only that, high yield toners with up to 3,000 colour pages offer unrivalled low total cost of ownership. Rest assured, this is the ideal multi-talented colour professional for your business.
Finding the Serial Number:
Toner Change:
Unboxing:
WiFi Set Up:
Kyocera ECOSYS M5526cdw - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Max Copying Speed
Up to 26 ppm (mono) / up to 26 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 600 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50Hz)
41.7 cm x 42.9 cm x 49.5 cm
26 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
Speed Dialing
100 station(s)
Remote Fax Retrieval (Polling)
Fax polling, Duplex Fax
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 26 ppm (A4) - colour , Printing: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - B/W , Copying: up to 26 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour , Scanning: up to 24 ipm (A4) - B/W duplex , Scanning: up to 16 ipm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
AC 230 V (50Hz)
375 Watt
Power Consumption Standby
41 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
29 sec
First Copy Out Time B/W
8 sec
First Copy Out Time Colour
10 sec
Consumables Included
1 x Cartridge (cyan) - up to 1200 pages , 1 x Cartridge (magenta) - up to 1200 pages , 1 x Cartridge (yellow) - up to 1200 pages , 1 x Cartridge (black) - up to 1200 pages
ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
ENERGY STAR Certified
41.7 cm
42.9 cm
49.5 cm
26 kg
Sound Emission
30 dBA (idle) / 49 dBA (operating)
CHKJ Kyocera TK 5240M Magenta Original Toner Cartridge In Stock £70.81
CHKJ Kyocera TK 5240C - cyan - original - toner cartridge In Stock £70.81
CHKJ Kyocera TK 5240Y Yellow Original Toner Cartridge In Stock £70.81
CHKJ Kyocera KYO Magenta Toner Cassette 3K In Stock £65.64
CHKJ Kyocera KYO Yellow Toner Cassette 3K In Stock £65.64
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Output Type: Colour
Technology: Laser
Max Print Speed: 26ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
