Kyocera ECOSYS M5521cdw A4 Colour Laser Multifunction
Quicklinx: CHKGWS00 Mfr#: 1102R93NL0
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
13 in stock
£221.09 ex VAT
£265.30 inc VAT
The ECOSYS M5521cdw A4 professional all-rounder meets any business requirements. The scan, copy, fax and mobile scan functions ensure an optimized and flexible workflow. Mobile printing support takes this to the next level and offers every office the most modern standards in technology. The direct printing functions (via Wi-Fi and USB host) keep your work running seamlessly.
  • Up to 21 pages per minute in A4 in colour and black and white
  • 1,200 dpi printing quality
  • WiFi and WiFi direct as standard
  • Mobile printing support including AirPrint, Mopria, KYOCERA Mobile Print
  • Double-sided print, copy, scan and fax functionality as standard
  • Direct printing from and scanning to USB flash memory
  • Compact design with low-noise printing
  • Exceptionally low printing costs in its class
Regardless of your business workflow requirements, this professional all-rounder will meet or exceed them. With all of the functionality you would expect, including scan, mobile scan, copy and fax, your workflow will be as optimised and as flexible as you require. Mobile print support takes this to the next level with support for both Apple and Android de-vices. In addition, the KYOCERA MyPanel app opens up the functionality of this device and enables you to operate the device via your smartphone. All in all, this powerful device fits seamlessly into any business.
Finding the Serial Number:
Toner Change:
Unboxing:
WiFi Set Up:
Kyocera ECOSYS M5521cdw - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
65000 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 21 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 9600 x 600 dpi (mono) / up to 9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50Hz)
41.7 cm x 42.9 cm x 49.5 cm
26 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - colour
65000 pages
Display
5 lines
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Copying Features
2 on 1, 4 on 1, ID Card Copy, electronic sorting, Auto Color Mode, Scan-once-copy-many
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF 1.7, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
11 sec
First Print Out Time Colour
12.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
Fax polling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
300 sheets
Max Media Capacity
550 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 21 ppm (A4) - colour , Printing: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - colour , Scanning: up to 30 ppm - B/W , Scanning: up to 23 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
AC 230 V (50Hz)
345 Watt
Power Consumption Standby
41 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
32 sec
First Copy Out Time B/W
10 sec
First Copy Out Time Colour
12 sec
ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
ENERGY STAR Certified
41.7 cm
42.9 cm
49.5 cm
26 kg
Sound Emission
30 dBA (idle) / 48 dBA (operating)
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Max Print Speed: 21ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: 150 - 300
