Brand
Kyocera ECOSYS M3645idn Mono Laser Multifunction Printer
Quicklinx: GBHVWS00 Mfr#: 1102V33NL0
£1,410.97 ex VAT
£1,693.16 inc VAT
These MFPs are a great choice for demanding work groups (small to large) looking for a compact, flexible and easy-to-use device combined with outstanding low running costs. Simplified login possibilities eliminate access bottlenecks while keeping the security of your documents high.
Kyocera ECOSYS M3645IDN - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 45 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 45 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 600 dpi
Display
7"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host
AirPrint Enabled
Office Machine Features
Scan to e-mail, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB, print from e-mail, IPP printing, scan to USB host
AC 230 V (50Hz)
47.5 cm x 47.6 cm x 57.5 cm
22.5 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display Diagonal Size
7"
Display Colour Support
Display Features
Touch screen, tilt, speaker
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
3 GB
Hard Disk Drive
128 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Up to 45 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, blank page skipping, electronic sorting
Printing
Max Printing Speed
Up to 45 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, TIFF, XPS, EPSON LQ-850, IBM Proprinter X24E, PRESCRIBE IIc, JPEG
Automatic Duplexing
First Print Out Time B/W
5.9 sec
Colour Management Features
Mopria
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Total Memory Capacity
Up to 256 pages
Fax Machine Features
Fax polling, Duplex Fax
Document & Media Handling
Max Original Size
Original Type
Sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
50 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), 70 x 148 mm, 148 x 140 mm
600 sheets
Max Media Capacity
2600 sheets
100 sheets
250 sheets
Input tray - 500 sheets size: 140 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , RADF size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 45 ppm (A4) - B/W , Printing: up to 22.5 ppm (A4) - B/W duplex , Copying: up to 22.5 ppm (A4) - B/W duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 , 2 x USB 2.0 host , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, AES, SNMP 3
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
AC 230 V (50Hz)
652 Watt
Power Consumption Standby
50 Watt
Power Consumption Sleep
0.5 Watt
Warm-Up Time
21 sec
First Copy Out Time B/W
7 sec
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
ENERGY STAR Certified
47.5 cm
47.6 cm
57.5 cm
22.5 kg
Sound Emission
30 dBA (idle) / 54 dBA (operating)
GBHV Kyocera Group E 3YR Onsite Warranty In Stock £236.91
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £1000 - £1500
