Kyocera ECOSYS M3145dn Colour Laser Multifunction Printer
Quicklinx: FJ63WS00 Mfr#: 1102TF3NL0
These MFPs are made for any team that needs high levels of versatility and productivity. Featuring fast print speeds, the additional features of double-sided scanning and copying as well as the integrated file compression function mean that these devices are ready to adapt to your changing needs. Thanks to their long-life components, these MFPs can achieve exceptionally low running costs as well as the low environmental impact you have come to expect from a genuine Kyocera.
  • Efficient connectivity
    With a range of connectivity options including AirPrint, Google Cloud Print, and Kyocera Mobile Print, this device ensures seamless integration into any workflow. Gigabit Ethernet and USB 2.0 ports offer high-speed connections to multiple devices.
  • Advanced security
    Equipped with AES, IPsec, SNMP 3, and SSL protocols, the Kyocera ECOSYS M3145DN provides robust security features to protect sensitive information, ensuring peace of mind for users.
  • High-speed copying and printing
    Achieve maximum productivity with fast copying and printing speeds up to 45 ppm and a first copy out time of just 7 seconds. Automatic duplexing enhances efficiency by facilitating double-sided printing and copying without manual intervention.
  • Versatile media handling
    This model boasts a flexible media handling capability, supporting sizes from A6 to Legal and weights from 50 to 220 g/m2. With a maximum media capacity of 2600 sheets, it meets the demands of high-volume tasks.
  • Eco-friendly design
    ENERGY STAR certification signifies this printer's commitment to energy efficiency. Kyocera's ECOSYS technology further enhances its environmental sustainability by reducing waste, making it an ideal choice for eco-conscious businesses.
Kyocera ECOSYS M3145DN - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 45 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 45 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
2600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
250 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Scan to e-mail, Kyocera ECOSYS Technology, scan to FTP, scan to SMB, print from e-mail, IPP printing, scan to USB host
AC 230 V (50Hz)
47.5 cm x 47.6 cm x 57.5 cm
22.3 kg
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
Display
5 lines x 21 characters
Display Features
Speaker, backlight
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
3 GB
Hard Disk Drive
128 GB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Up to 45 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo, map
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, blank page skipping, electronic sorting
Printing
Max Printing Speed
Up to 45 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, KPDL3, PCL 6 (XL), PDF, TIFF, XPS, EPSON LQ-850, IBM Proprinter X24E, PRESCRIBE IIc, JPEG
Automatic Duplexing
First Print Out Time B/W
5.9 sec
Colour Management Features
Mopria
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
50 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm), 70 x 148 mm, 148 x 140 mm
600 sheets
Max Media Capacity
2600 sheets
100 sheets
250 sheets
Input tray - 500 sheets size: 140 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , RADF size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 50 g/m² - 120 g/m² , Output tray - 250 sheets
Speed Details
Printing: up to 45 ppm (A4) - B/W , Printing: up to 22.5 ppm (A4) - B/W duplex , Copying: up to 22.5 ppm (A4) - B/W duplex , Scanning: up to 60 ipm (A4) - B/W (300 dpi) , Scanning: up to 40 ipm (A4) - colour (300 dpi) , Scanning: up to 26 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 17 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 , 2 x USB host , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
SSL, IPsec, AES, SNMP 3
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
AC 230 V (50Hz)
652 Watt
Power Consumption Standby
50 Watt
Power Consumption Sleep
0.5 Watt
Warm-Up Time
16 sec
First Copy Out Time B/W
7 sec
TUV GS, ISO 9001, ISO 14001, ISO 7779, ISO 9296
ENERGY STAR Certified
47.5 cm
47.6 cm
57.5 cm
22.3 kg
Sound Emission
30 dBA (idle) / 54 dBA (operating)
FJ63 Kyocera TK 3160 Black Toner Kit for ECOSYS P3045dn In Stock £76.70
