Kyocera A3 FS-C8600DN Colour Laser Printer
Quicklinx: C3LLWS00 Mfr#: 1102N13NL0
The Kyocera FS-C8600 A4 Colour Laser Printer is ideal for workgroups with high volume needs who demand a specific, professional quality, secure print solution. The FS C8600 delivers A3 print speeds of 22 ppm in colour and mono, with automatic duplex for double sided documents and 1024Mb of RAM to aid larger document processing with support for local storage of commonly used graphics and forms to reduce network loads. The FSC 8600 boasts flexibile media handling options, including stapling, hole punching, folding and document sorting. Integrated security features like departmental codes and command center enable access and user function restrictions, thus increasing document security and allowing status monitoring locally or via a web browser.
Kyocera FS-C8600DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
111 kg
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Max Media Size (Custom)
304.8 mm x 1219 mm
Print Speed
Up to 22 ppm - B/W - A3 (297 x 420 mm) , Up to 22 ppm - colour - A3 (297 x 420 mm) , Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 45 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
9600 x 600 dpi
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB, Gigabit LAN, USB host
PowerPC 750GL 750 MHz
RAM Installed (Max)
1 GB (2 GB)
Card Reader
Hard Drive
160 GB
Language Simulation
PostScript 3, PCL 6, PRESCRIBE IIe, XPS, PDF 1.7
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Plain paper, banners
Total Media Capacity
1150 sheets
Media Handling
2x 500-sheet input trays, 150-sheet multipurpose tray
Monthly Duty Cycle (max)
225000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
Printer Features
Kyocera ECOSYS Technology
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
Microsoft Certification
Compatible with Windows 7
67.2 cm x 78.7 cm x 74.4 cm
Printer Type
Printer
Print Speed
Wired
9600 x 600 dpi
9600 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5.4 sec
First Print Out Time Colour
6.6 sec
Language Simulation
Fonts Included
93 x scalable PCL , 136 x scalable PostScript , 1 x bitmapped , 45 x barcode
Barcodes
Printer Features
Media Handling
RAM
RAM Installed (Max)
1 GB / 2 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
CompactFlash Card
Storage
Hard Drive
160 GB
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
304.8 mm x 1219 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 300 g/m²
1150 sheets
Media Feeders
2 x automatic - 500 sheets - ARCH B (304.8 x 457.2 mm) weight: 60 g/m² - 256 g/m² , 1 x automatic - 150 sheets - 304.8 x 1219.2 mm weight: 60 g/m² - 300 g/m²
Max Media Capacity
7650 sheets
Output Trays Capacity
750 sheets
Duty Cycle
225000 pages
Print server
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP
Expansion Slots
1 x expansion slot , Memory
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 15000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 10000 pages ISO/IEC 19798
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
1140 Watt
Power Consumption Stand by / Sleep
170 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
33.9 dBA
Sound Emission (Operating)
52.6 dBA
67.2 cm
78.7 cm
74.4 cm
111 kg
