The Konftel Ego is a personal speakerphone. It's compact and portable and fits easily inside your briefcase, wherever you're going. Despite its size, the Konftel Ego delivers crystal clear sound thanks to the unique OmniSound audio technology. It's ideal for a meeting with a couple of colleagues in one of your smaller conference rooms. Or in a hotel room, while you're away from the office. If you're alone in the room, the Konftel Ego is a good alternative to a headset.
The Konftel Ego works seamlessly with conferencing tools. It connects easily to a PC via a USB port or to a tablet or smartphone via Bluetooth. Moreover, the Konftel Ego has support for ultra-fast Bluetooth pairing through NFC (near-field communication) and HD quality calls. With Bluetooth A2DP (advanced audio distribution profile) you can play your favorite music with superior audio performance, when your meeting has finished. The clear and attractive LCD display screen lets you see at a glance, which feature is enabled. This is also shown by the LEDs, which shine downwards. The Konftel Ego has a headset port, and the built-in battery gives you the possibility of completely cordless use.
- Konftel Ego - speaker phone
- Product Type
- Speaker phone - Bluetooth - wireless - USB
- Recommended Use
- Computer - communication
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Microphones Included
- 2
- 2 years warranty
- Product Type
- Speaker phone - Bluetooth - USB
- Display
- LCD
- 14.5 cm
- 13.5 cm
- 3.2 cm
- 230 g
- Recommended Use
Headphones
- Wireless
- Bluetooth
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
Microphone
- Directivity Angle
- 360°
- 2
- Frequency Response
- 50 - 24000 Hz
- Max Sound Pressure
- 90 dB
- Audio Input Details
- Omni-directional
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B) , Headset (mini-phone 3.5mm)
- Cables Included
- USB cable
- Included Accessories
- Soft case
- Battery
- Speaker phone battery rechargeable - Lithium Ion
- Capacity
- 1000 mAh
- Run Time (Up To)
- 12 hour(s)
- Limited warranty - 2 years
