Konftel EGO Conference Phone
Quicklinx: CKMMWS00 Mfr#: 910101081
£76.48 ex VAT
£91.77 inc VAT
The Konftel Ego is a personal speakerphone. It's compact and portable and fits easily inside your briefcase, wherever you're going. Despite its size, the Konftel Ego delivers crystal clear sound thanks to the unique OmniSound audio technology. It's ideal for a meeting with a couple of colleagues in one of your smaller conference rooms. Or in a hotel room, while you're away from the office. If you're alone in the room, the Konftel Ego is a good alternative to a headset.
The Konftel Ego works seamlessly with conferencing tools. It connects easily to a PC via a USB port or to a tablet or smartphone via Bluetooth. Moreover, the Konftel Ego has support for ultra-fast Bluetooth pairing through NFC (near-field communication) and HD quality calls. With Bluetooth A2DP (advanced audio distribution profile) you can play your favorite music with superior audio performance, when your meeting has finished. The clear and attractive LCD display screen lets you see at a glance, which feature is enabled. This is also shown by the LEDs, which shine downwards. The Konftel Ego has a headset port, and the built-in battery gives you the possibility of completely cordless use.
  • Perfect for your meeting tools
    The speakerphone works seamlessly with Microsoft Teams, Cisco Webex, Zoom, Avaya IX Workplace and many other collaborative tools. It connects easily to a computer via USB or to a tablet or smartphone via Bluetooth . After the meeting, you can then fill the room with your favorite music.
  • The right tool for the moment
    The Konftel Ego is perfect for holding a meeting with a couple of colleagues in one of your smaller huddle rooms. Or maybe in a hotel room when you're travelling. If you're on your own, the Konftel Ego is a great alternative to a headset.
  • So easy to use
    A smart and clear LCD screen makes it easy to see which function is active. LEDs also light up on the side in different colors to indicate the function. In short, the Konftel Ego gives you full and effortless control.
  • A highly convenient video solution
    Are you after a package solution for small huddle rooms? The Konftel C20Ego collaboration kit combines the Konftel Ego with the Konftel Cam20, which delivers 4K Ultra HD and a razor-sharp image. The Konftel OCC Hub brings the whole package together, so a single USB cable is all you need to connect the conference cam, the sound device and the room's screen to the collaboration app on your laptop. How about that for convenience in a box!
  • Climate neutral products
    Konftel is certified in line with the Climate Neutral standard. This means that we have offset all our greenhouse gas emissions and are taking action to further reduce those emissions. When you choose a Konftel product, you keep a clear climate conscience while supporting your organization's growing need for video collaboration. Keep an eye out for the Climate Neutral Certified label, which indicates that all our products are climate neutral.
Konftel Ego - speakerphone
Speakerphone - Bluetooth - wireless - USB
Recommended Use
Computer - communication
Wireless
Wireless Technology
Bluetooth
Microphones Included
2
Display
LCD
14.5 cm
13.5 cm
3.2 cm
230 g
Recommended Use
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Microphone
Directivity Angle
360°
2
Frequency Response
50 - 24000 Hz
Max Sound Pressure
90 dB
Audio Input Details
Omni-directional
Connector Type
USB 2.0 (5 pin Micro-USB Type B) , Headset (mini-phone 3.5mm)
Soft case
Cable Details
USB cable
Speaker phone battery rechargeable - Lithium Ion
1000 mAh
Run Time (Up To)
15 hours
