Product
Konftel EGO Conference Phone
Quicklinx: CKMMWS00 Mfr#: 910101081
25 in stock
£86.65 ex VAT
£103.98 inc VAT
The Konftel Ego is a personal speakerphone. It's compact and portable and fits easily inside your briefcase, wherever you're going. Despite its size, the Konftel Ego delivers crystal clear sound thanks to the unique OmniSound audio technology. It's ideal for a meeting with a couple of colleagues in one of your smaller conference rooms. Or in a hotel room, while you're away from the office. If you're alone in the room, the Konftel Ego is a good alternative to a headset.
The Konftel Ego works seamlessly with conferencing tools. It connects easily to a PC via a USB port or to a tablet or smartphone via Bluetooth. Moreover, the Konftel Ego has support for ultra-fast Bluetooth pairing through NFC (near-field communication) and HD quality calls. With Bluetooth A2DP (advanced audio distribution profile) you can play your favorite music with superior audio performance, when your meeting has finished. The clear and attractive LCD display screen lets you see at a glance, which feature is enabled. This is also shown by the LEDs, which shine downwards. The Konftel Ego has a headset port, and the built-in battery gives you the possibility of completely cordless use.
Konftel Ego - speaker phone
Speaker phone - Bluetooth - wireless - USB
Recommended Use
Computer - communication
Wireless
Wireless Technology
Bluetooth
Microphones Included
2
2 years warranty
Speaker phone - Bluetooth - USB
Display
LCD
14.5 cm
13.5 cm
3.2 cm
230 g
Recommended Use
Headphones
Wireless
Wireless Technology
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Microphone
Directivity Angle
360°
2
Frequency Response
50 - 24000 Hz
Max Sound Pressure
90 dB
Audio Input Details
Omni-directional
Connector Type
USB 2.0 (5 pin Micro-USB Type B) , Headset (mini-phone 3.5mm)
USB cable
Soft case
Speaker phone battery rechargeable - Lithium Ion
1000 mAh
Run Time (Up To)
12 hour(s)
Brand: Konftel
Price Range Ex VAT: 50 - 100
