The Konftel 55Wx is an easy-to-use and compact speaker phone with the patented OmniSound audio technology. HD audio produces crystal-clear and more natural-sounding speech than the sound you get with conventional phone calls. All the nuances come through, making conversation more fluid. This also applies when the conference unit is connected wirelessly via Bluetooth.
The Konftel 55Wx provides UC with no restrictions; versatile and integrated communication whatever your tool of choice. The conference unit connects direct to Skype for Business, Cisco Jabber or Avaya Communicator on your PC. The smart feature layer in the 55 series software makes call functions in the UC client available on the touch screen.
But that's not all. The Konftel 55Wx has been designed to serve as the hub of your communications. In addition to PCs, it also connects to mobile phones, tablets and desktop phones. VoIP calls can be bridged with calls via a desktop or mobile phone, and switching and combining connections is simple using the screen's smart user interface that only displays the current connections. Just make a call to start your meeting!
The Konftel 55Wx is equally well suited to the desktop, home office or conference room. Using expansion microphones, larger conference calls with up to 20 participants can also be catered for.
A convenient hub
The speakerphone serves as a hub for your communications, connecting to computers, mobile phones/tablets and desk phones. The Konftel 55Wx also has Bluetooth for easier pairing, as an extra feature compared with the simpler Konftel 55. Calls via a computer can be bridged with calls via a desk phone or mobile phone. Switch and combine connections easily on the touchscreen, which only shows the options available at the time. -
Connects to your UC app
The Konftel 55Wx is fully compatible with the market's leading UC applications. The speakerphone connects directly to Skype for Business, Cisco Jabber or Avaya Communicator on your computer. The app's call functions are controlled from the touchscreen. If you prefer a different conferencing tool, the Konftel 55Wx is still a high-quality USB audio device. -
Grows with the task
The Konftel 55Wx is the perfect addition to huddle and medium sized rooms that are so crucial to the growing culture of teamwork within and between organizations. But it's just as good on a desk and with expansion microphones, you can have conference calls in large rooms. -
Smart features
Record calls or dictations onto a memory card and save, play or share the audio files with ease. The software is constantly being improved and can be updated easily using a tool on your computer. This makes the Konftel 55Wx speakerphone a future-proof investment. -
A highly conveniant video solution
Are you after a package solution for small and medium meeting rooms? The Konftel C5055Wx combines the Konftel 55Wx with the Konftel Cam50, a PTZ conference camera with 12x optical zoom and exceptional image quality. The Konftel OCC Hub brings the whole package together, so a single USB cable is all you need to connect the conference cam, the sound device and the room's screen to the collaboration app on your laptop. -
Climate neutral products
Konftel is certified in line with the Climate Neutral standard. This means that we have offset all our greenhouse gas emissions and are taking action to further reduce those emissions. When you choose a Konftel product, you keep a clear climate conscience while supporting your organization's growing need for video collaboration. Keep an eye out for the Climate Neutral Certified label, which indicates that all our products are climate neutral.
- Konftel 55Wx - Bluetooth conference unit for conference phone
- Product Type
- Intended For
- Conference phone
- Wireless Interface
- Bluetooth, NFC
- Battery
- Rechargeable
- Run Time (Up To)
- 9 hours
- Package Content
- AC power adaptor, rechargeable battery, conference unit
- 22.2 cm x 20.6 cm x 6.8 cm
- 640 g
- Silver, liquorice black
- 2-year warranty
- Designed For
- Konftel 55Wx
- Product Type
- Intended For
- Conference phone
- Display
- LCD display 240 x 320
- Bluetooth 3.0, NFC
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Package Content
- 22.2 cm
- 20.6 cm
- 6.8 cm
- 640 g
- Connections
- Headset - mini-phone 3.5mm , USB 2.0 , Cellular phone input , Phone line
- Rechargeable Battery
- Rechargeable
- Technology
- Lithium polymer
- Capacity
- 2260 mAh
- Run Time (Up To)
- 9 hours
- 2 years
- Designed For
- Konftel 55Wx
