Konftel 55WX Wireless Conferencing Unit
Quicklinx: CBH2WS00 Mfr#: 910101082
11 in stock
£281.08 ex VAT
£337.29 inc VAT
The Konftel 55Wx is an easy-to-use and compact speaker phone with the patented OmniSound audio technology. HD audio produces crystal-clear and more natural-sounding speech than the sound you get with conventional phone calls. All the nuances come through, making conversation more fluid. This also applies when the conference unit is connected wirelessly via Bluetooth.
The Konftel 55Wx provides UC with no restrictions; versatile and integrated communication whatever your tool of choice. The conference unit connects direct to Skype for Business, Cisco Jabber or Avaya Communicator on your PC. The smart feature layer in the 55 series software makes call functions in the UC client available on the touch screen.
But that's not all. The Konftel 55Wx has been designed to serve as the hub of your communications. In addition to PCs, it also connects to mobile phones, tablets and desktop phones. VoIP calls can be bridged with calls via a desktop or mobile phone, and switching and combining connections is simple using the screen's smart user interface that only displays the current connections. Just make a call to start your meeting!
The Konftel 55Wx is equally well suited to the desktop, home office or conference room. Using expansion microphones, larger conference calls with up to 20 participants can also be catered for.
  • OmniSound
    The patented OmniSound audio technology guarantees an impressive and crystal-clear full-duplex audio in both directions. The sound is transmitted clearly and powerfully to all attendees thanks to a hypersensitive microphone with 360° audio pick-up and speakers. OmniSound delivers HD audio in calls over IP and provider networks. It also incorporates automatic echo cancellation and noise suppression, which minimizes background noise interference. This means you can walk around in the room, talking, discussing and debating with others without loss of audio quality and without any annoying sound clipping, damping or echoes. It's as close to real sound as you can get.
  • Headset connection
    Connect your 3.5 mm headset and handle calls via all connected units from the same location. Turn off the headset symbol on the touch screen to return to speaker call.
  • Color touch screen
    The Konftel 55 series is very simple to use. The clear symbols and touch buttons on the color screen change according to the device's connections - computer, desktop phone, mobile phone or headset, which makes it easy to switch connections. Moreover, VoIP calls can be bridged with calls via a desktop phone or mobile phone/tablet. Settings, ring signals, tone, etc. can be adapted to suit your wishes in several languages.
  • SD call recording
    Recording calls to an SD memory card is perfect for interviews, documentation, or simply as a reminder of important calls and meetings. Can also be used as a dictaphone.
Konftel 55Wx - Bluetooth conference unit
Intended For
Conference phone
Wireless Interface
Bluetooth, NFC
Rechargeable
Run Time (Up To)
9 hours
Package Content
AC power adaptor, rechargeable battery, conference unit
22.2 cm x 20.6 cm x 6.8 cm
640 g
Silver, liquorice black
Konftel 55Wx
Intended For
Conference phone
Display
LCD display 240 x 320
Wireless Interface
Bluetooth 3.0, NFC
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Package Content
22.2 cm
20.6 cm
6.8 cm
640 g
Headset - mini-phone 3.5mm , USB 2.0 , Cellular phone input , Phone line
Rechargeable Battery
Rechargeable
Lithium polymer
2260 mAh
Run Time (Up To)
9 hours
2 years
Konftel 55Wx
Brand: Konftel
Price Range Ex VAT: 150 - 300
