Konftel 300Wx Wireless Expandable Conference Phone
Quicklinx: B13DWS00 Mfr#: 910101077
£430.53 ex VAT
£516.63 inc VAT
The Konftel 300Wx allows you to hold conference calls where and when it is convenient - without worrying about phone jacks and power outlets. The rechargeable lithium ion battery ensures superior performance with long talk time, this allows a full working week without worrying about recharging! The Konftel 300Wx supports DECT with GAP/CAT-Iq standard for less interference and clearer conversations and moreover is easily integrated with existing DECT systems for complete coverage. The Konftel 300Wx can also be easily connected to your cell phone or computer via USB for VoIP calls over the Internet. Its embedded line mode enables you to connect DECT, cell phones and USB simultaneously for multi-party calls. The Konftel 300Wx has several smart features to make your meetings as easy and efficient as possible. Record calls on a SD memory card, listen to it later or share it with others. The built-in conference guide helps you dial multi-party calls, store call groups and initiate reoccurring meetings. The Konftel 300Wx is expandable with microphones, equipped with Konftel OmniSound audio technology for crystal clear sound and its elegant Scandinavian design makes it a welcome addition to any conference room.
  • First-rate audio quality
    Give your conference calls the full dynamics they deserve! With HD sound, voices are much more natural than in a conventional phone call. The nuances come through and the entire dialog can flow more smoothly. With expansion microphones, you can have large conference calls.
  • You're in control
    Konftel 300Wx and the Konftel Unite mobile app are the perfect combination. Via the optional Konftel Unite adapter, you can connect up the app and manage the conference phone effortlessly. With our One Touch Conferencing, one touch really is all it takes to start or join a meeting. Use your personal contact book and control the phone's functions during the meeting.
  • Perfect for collaboration
    A USB port makes the Konftel 300Wx ready for all the apps and services we use to communicate and collaborate via computers – such as Microsoft Teams, Skype, Cisco Webex, Zoom, Google Hangouts, Avaya IX Workplace and Unify Circuit. Don't compromise on audio quality when your teamwork goes "live" in an online meeting.
  • Smart features
    The Konftel 300Wx is packed with smart features: Call via a mobile phone connected by cable, as an alternative to DECT and USB. Use the line selector to switch easily between DECT, USB and mobile phone connections, or connect calls. Record meetings on an SD memory card. The conference guide will take you through the steps to set up a multi-party call and save call groups.
  • A highly convenient video solution
    Are you after a package solution for video in your meeting rooms? The Konftel C50300Wx Hybrid combines the Konftel 300Wx with the Konftel Cam50, a PTZ conference camera with 12x optical zoom and exceptional image quality. The Konftel OCC Hub brings the whole package together, so a single USB cable is all you need to connect the conference cam, the conference phone and the room's screen to the collaboration app on your laptop. The hybrid concept also delivers the freedom to welcome participants via regular phone calls.
  • Climate neutral products
    Konftel is certified in line with the Climate Neutral standard. This means that we have offset all our greenhouse gas emissions and are taking action to further reduce those emissions. When you choose a Konftel product, you keep a clear climate conscience while supporting your organization's growing need for video collaboration. Keep an eye out for the Climate Neutral Certified label, which indicates that all our products are climate neutral.
Konftel 300Wx Analog - cordless conference phone - 3-way call capability
Cordless conference phone
Cordless Phone Standard
DECT\GAP
Package Content
Conference phone console, Conferencing base unit
Speakerphone
Yes (digital duplex)
Call Services
Call Hold
Display
LCD display - monochrome - Yes
Body Colour
Liquorice black
Europe
Body Colour
Liquorice black
Europe
Phone Features
DECT\GAP
Call Services
Call Hold
Max Handsets Supported
7
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
200 m
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Speakerphone
Voice Recording
Menu Operation
Computer Link
Yes (USB)
Firmware Upgradable
Additional Functions
Built-in clock, voice recording
Additional Features
PIN code, built-in SD card slot
Conference Phone
Package Content
USB connection for VoIP calls, OmniSound HD
Phone Memory
Phone Directory Capacity
200 names & numbers
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Backlit
Supported Flash Memory Cards
SD Memory Card
USB / mini-USB Type B , 2 x microphone jack , Cellular phone connection headset jack
USB cable - 1.5 m , Power cable - 7.5 m
Charging stand, phone base, power adapter
FCC Part 68, IEC 60950-1, EN 60950-1, EN 301 406, EN 301 489-1, EN 301 489-6
5200 mAh
Rechargeable - Lithium Ion
Included Qty
1
Talk Time
Up to 3600 min
Standby Time
Up to 270 h
Dimensions & Weight (Base)
24 cm
24 cm
7.7 cm
1 kg
Brand: Konftel
