Your basket is empty
Konftel 300M conference phone
Quicklinx: B13CWS00 Mfr#: 910101070
The Konftel 300M is perfect for companies that have mobile communications solutions. In addition to benefiting from the flexibility of its mobile solution, your company can have an uncompromising conference phone with smart functions and Konftel's patented audio technology, OmniSound 2.0, which ensures crystal-clear sound on all conference calls. Other useful features include the ability to record to an SD memory card, SMS capabilities, and a conference guide that helps you save call groups - a huge help if you make regular multi-party calls. The USB computer connection enables you to make VoIP calls, and you can use the Konftel 300M in environments with unified communications solutions. Mobile and USB connections are easy to combine and switch using the phone's line mode. With the battery charged and the SIM card fitted, the Konftel 300M is excellent for anyone who needs to get large or small meetings going quickly!
Konftel 300M - liquorice black - 3G GSM - mobile conference phone
Mobile conference phone 3G
Display
LCD display - 128 x 64 pixels - monochrome
SD Memory Card slot - up to 2 GB
Service Provider
Not specified
Messaging Services
SMS
Talk Time
Up to 1800 minutes
Standby Time
Up to 270 hours
Europe
Liquorice black
240 mm x 240 mm x 77 mm
1180 g
2 years warranty
240 mm
240 mm
77 mm
1180 g
Body Colour
Liquorice black
Europe
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
3G
Service Provider
Not specified
Messaging & Internet
Messaging Services
SMS
Communications
2G Band
GSM 850/900/1800/1900
Phone Features
Phone Functions
Speakerphone, conference call
Additional Features
VoIP over USB
Organiser
Phone Book Entries Qty
500
Supported Flash Memory Cards
SD Memory Card - up to 2 GB
Display
LCD display - monochrome
Display Resolution
128 x 64 pixels
Connector Type
USB
Lithium
5200 mAh
Talk Time
1800 minutes
Standby Time
270 hours
Run Time Details
Talk: up to 1800 min , Standby: up to 270 hrs
EN 60950-1, EN 301.489.7, EN 301.489.24, EN 301.511, FCC CFR47 Part 15 B, EN 301.908
USB cable, power adapter, power cable, battery charger
5 °C
20 - 80%
