Konftel 300 IP Full Duplex Conference Phone
Quicklinx: 9Y8PWS00 Mfr#: 910101079
£334.11 ex VAT
£400.93 inc VAT
The Konftel 300IP is a flexible SIP-based conference phone that is ideal for companies using IP telephony. It is equipped with Konftel's patented audio technology OmniSound 2.0 with wideband to ensure a clear and natural sound. The stylishly designed Konftel 300IP is packed with intelligent functions to make teleconferences more efficient even in larger conferences.
With the Konftel 300IP your company will have a top-quality conference phone that combines all the benefits of IP telephony with innovative new functions.
The conference phone of the future is here, SIP-based, filled with innovative functions and with a stunning, Scandinavian design. Meet the Konftel 300IP. Made by Europe's leading manufacturer of conference phones designed for efficient phone meetings.
  • Tried and tested
    The Konftel 300IP is a big favorite with companies and organizations around the world. This is due to the winning combination of product quality, practical features and design. As a SIP telephone, it has been tested and validated for a wide range of popular IP platforms, in accordance with Konftel's strategy.
  • Smart features
    This is a proper conference telephone. The built-in bridging function handles five-way calls, which reduces the need for external bridging services. The conference guide makes it easy to call up groups at the touch of a button. Another popular feature of the Konftel 300IP is recording onto an SD memory card.
  • Grows with the task
    The Konftel 300IP fits everything from small rooms to large auditoriums. It includes the option to connect a pair of expansion microphones to increase the room pickup range. You can also connect a wireless headset if you're lecturing. If you use the PA interface box to connect to a PA system, there is no limit to the size of the meeting room.
  • Easy for the administrator
    The Konftel 300IP can be configured and updated via the web interface or the company's own provisioning server. Another convenient option is Konftel's web service Zero Touch Installation. You can also download new software and update the phone offline.
  • Climate neutral products
    Konftel is certified in line with the Climate Neutral standard. This means that we have offset all our greenhouse gas emissions and are taking action to further reduce those emissions. When you choose a Konftel product, you keep a clear climate conscience while supporting your organization's growing need for video collaboration. Keep an eye out for the Climate Neutral Certified label, which indicates that all our products are climate neutral.
Konftel 300IP - conference VoIP phone - 5-way call capability
Conference VoIP phone
Compatible Platforms
Mitel Networks 3300 Integrated Communications Platform, Ascotel, OmniPCX Enterprise, Ericsson MX-ONE
VoIP Protocols
SIP, SIP v2
Voice Codecs
G.722, G.729ab, G.711u, G.711a
Package Content
Conference phone console
Speakerphone
Call Services
Call Waiting, Call Hold
Display
LCD display - monochrome - Yes
Network Ports Qty
1 x Ethernet 10/100Base-TX
Compatible Software
Avaya CallManager, Cisco CallManager
Body Colour
Liquorice black
Body Colour
Liquorice black
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
5-way
Speakerphone
Voice Recording
Menu Operation
Additional Functions
Built-in clock, voice recording
Additional Features
Music on hold, built-in web server, built-in SD card slot
Conference Phone
Package Content
IP Telephony
VoIP
VoIP Protocols
SIP, SIP v2
Voice Codecs
Quality of Service
IEEE 802.1Q (VLAN), Differentiated Services (DiffServ)
IP Address Assignment
DHCP, static
Security
IEEE 802.1X, TLS
Power Over Ethernet (PoE) Support
Network Protocols
TCP, TFTP, UDP, HTTP, SNMP, Link Layer Discovery Protocol (LLDP), SNTP, NTP
Network Ports Qty
Compatible Software
Network Features
Network Address Translation (NAT), Lightweight Directory Access Protocol (LDAP)
Phone Memory
Phone Directory Capacity
1000 names & numbers
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Backlit
Headset jack , Network / RJ-45 , Microphone jack
Network cable - 6.5 m
FCC Part 15 B, FCC Part 15 C, RoHS, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, EN 301 489-3
Dimensions & Weight (Base)
24 cm
24 cm
7.7 cm
1 kg
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9Y8P 046383
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £50.17
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
