Kodak ScanStation 710 A4 Colour Document Scanner
Quicklinx: CCMCWS00 Mfr#: 1877398
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 215 x 863 mm
Interface: Gigabit LAN
Compatibility: PC
£1,095.63 ex VAT
£1,314.75 inc VAT
Seamless connector. Project archiver. Instant messenger. Exceptional performer. With capabilities like these, the Kodak Scan Station 710 has more functionality than you’d ever expect. And with its intuitive touchscreen, simple network setup, and robust remote management, it can give you an edge right out of the box. Which means the Kodak Scan Station 710 is more than a scanner. It’s your new information manager.
  • User-friendly experience
    Combine the bright, easy-to-navigate touchscreen, intuitive user controls, and administrator controlled functionality for a user experience that promises fewer mistakes and faster proficiency without the distraction of a separate PC. And Scan Station's quiet operation makes it office friendly.
  • Simple and robust remote management
    If you have many networked Scan Stations throughout your business, a system administrator can efficiently configure and maintain these devices on your network from one place.
  • Information management made easy
    With increased ease of operation and improved file naming and security features, scanned content can be classified, organized, and searched by ad hoc users with minimal training while maintaining the degree of accessibility and security you've established.
  • More than scanning - doing
    The Scan Station 710 turns documents into actionable information. It connects directly to your network to make capturing information to your business processes and applications fast and easy. You can also send digital files to multiple destinations.
Kodak Scan Station 710 - document scanner - desktop - Gigabit LAN
Document scanner - desktop
Interface Type
Gigabit LAN
Scan Element Type
Dual CCD
Additional Functions
Email, fax, scan to print, scan to network share, scan to USB, scan to FTP
Max Supported Document Size
215 x 863 mm
Input Type
Grayscale / Color Depth
30-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
70 ppm (mono) / 70 ppm (colour)
Max Document Size
215 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card
Document Storage Capacity
75 sheets
Duty Cycle
6000 scans per day
Microsoft Windows Vista SP2, Microsoft Windows XP SP3, Microsoft Windows 7 SP1, Windows 8
35.6 cm x 38.2 cm x 20.6 cm
10.5 kg
Environmental Standards
ENERGY STAR Qualified
90 days warranty
Interface Type
Gigabit LAN
215 x 863 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
Dual CCD
Max Document Scan Speed B/W
70 ppm
Max Document Scan Speed Colour
70 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
70 ppm - portrait B&W - Letter - 200 dpi , 70 ppm - portrait colour - Letter - 200 dpi , 70 ppm - greyscale - Letter - 200 dpi , 140 ipm - duplex - portrait B&W - Letter - 200 dpi , 140 ipm - duplex - portrait colour - Letter - 200 dpi , 140 ipm - duplex - greyscale - Letter - 200 dpi
Scanner Features
Scan to portable USB drive, Color Dropout, built-in speaker, Automatic Image Orientation, Blank Page Removal, built-in microphone, Auto Crop, Perfect Page, Ultrasonic Multi Feed Detection, Deskew, 9.7" touch screen LCD display
Media Handling
Max Document Size
215 mm x 863 mm
75 sheets
Gigabit LAN
FCC Class B certified, TUV, TUV GS, CCC, FCC CFR47 Part 15, S Mark, TUV C, ICES-003 issue 5 Class B, EN55024:2010, GB4943.1-2011, RCM, BSMI CNS 14336-1, EN60950-1:2006 +A11+A1+A12, UL 60950-1:2007, EN55022:2010 Class B, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-CISPR 22-10, CAN/CSA C22.2 No. 60950-1-07+A11:2011, GB 9254-2008 Class B, IEC60950-1:2005+A1, CNS13438:2006 Class B
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
50 Watt
Power Consumption Sleep
4 Watt
Software Included
Drivers & Utilities
System Requirements Details
Core 2 Duo - 2.4 GHz - RAM 4 GB (USB 2.0)
35.6 cm
38.2 cm
20.6 cm
10.5 kg
Limited warranty - 90 days
10 °C
35 °C
10 - 85%
Compatibility: PC
Brand: Kodak
Price Range Ex VAT: 1000 - 1500
