Kodak SCANMATE i940 Document Scanner
Quicklinx: 9KXWWS00 Mfr#: 1960988
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The only thing worse than data trapped on paper is information trapped in your computer. With the compact Kodak Scanmate i940 scanner, collecting, managing, and distributing information is simple and desktop-friendly.
Kodak's smart touch functionality replaces complicated multi-step scanning processes with one-touch simplicity. So, you get compact with a huge impact.
Create email attachments, picture files, and searchable PDFs - and get your documents to the cloud, so they can be accessed wherever you are. With the i940, you can scan directly to cloud-based applications.
And, the USB-powered capability lets you bring all this functionality with you, wherever you go. Capture, process, and send information effortlessly.
Kodak SCANMATE i940 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 1524 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
20 ppm (mono) / 15 ppm (colour)
Max Document Size
216 mm x 1524 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
1000 scans per day
Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits), Ubuntu 16.04 LTS, Apple macOS 10.13 or later
Microsoft Certification
Compatible with Windows 7
29 cm x 10.7 cm x 7.9 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Interface Type
USB 2.0
216 x 1524 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Dual CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
15 ppm
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - portrait B&W - Letter - 200 dpi , 20 ppm - portrait greyscale - Letter - 200 dpi , 15 ppm - portrait colour - Letter - 200 dpi , 40 ipm - duplex - portrait B&W - Letter - 200 dpi , 40 ipm - duplex - portrait greyscale - Letter - 200 dpi , 30 ipm - duplex - portrait colour - Letter - 200 dpi , 8 ppm - portrait (USB bus powered) - Letter - 200 dpi , 16 ipm - duplex - portrait (USB bus powered) - Letter - 200 dpi
Scanner Features
Powered by USB port, Color Dropout, Blank Page Removal, Auto Crop, Auto Deskew
Scan File Formats
BMP, JPEG, TIFF, PDF, RTF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 1524 mm
Automatic
20 sheets
USB 2.0 - Type B
1 x USB cable , 1 x USB power cable
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
15 Watt
Power Consumption Sleep
1 Watt
Software Included
Drivers & Utilities, KODAK Smart Touch, NewSoft Presto! PageManager, Presto! BizCard Xpress, KODAK Capture Pro Software Limited Edition
29 cm
10.7 cm
7.9 cm
1.3 kg
Limited warranty - advance hardware replacement - 3 years
10 °C
35 °C
10 - 85%
Sound Emission
58 dB
