Say goodbye to the days of slow flatbed scanning! Scanning pictures and other memorabilia is now fast and easy - with great profit potential - thanks to the Kodak Picture Saver Scanning Systems PS50. Just think - while it used to take one to two minutes to scan a single photo on a flatbed, you can now scan up to 85 photos in just one minute!
Gentle photo handling
With the Kodak gentle photo separation module, the specially designed transport treats every photo with extra-gentle care. -
Kodak Perfect Touch technology built in
For bright, vibrant colors and rich detail in addition to the ability to improve contrast and color balance and correct red eye. -
Flexible workflow
Start, stop, or reopen an existing scanning job at any point in the capture-edit-output cycle; this gives you the flexibility. -
Automatic image straightening
It delivers auto deskew for proper image alignment. -
Software-based image cleaning
Reduce artifacts from environmental factors, such as dust.
- Kodak Picture Saver Scanning System PS50 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 215 x 863 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 50 ppm (mono) / 50 ppm (colour)
- Max Document Size
- 302 mm x 461 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows XP SP3, Microsoft Windows XP 64-bit Edition SP2, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- 33 cm x 16.2 cm x 24.6 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 215 x 863 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 50 ppm
- Max Document Scan Speed Colour
- 50 ppm
- Scanner Speed Details
- 50 ppm - landscape - 10x15cm - 300 dpi
- Scanner Features
- Color Dropout, Automatic Image Orientation, automatic colour detection, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, Deskew
- TWAIN
Media Handling
- Max Document Size
- 302 mm x 461 mm
- Plain paper
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0
- Included Accessories
- Dust cover
- GOST, CISPR 22 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, CCC, FCC CFR47 Part 15 B, S Mark, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, ICES-003 issue 4 Class B, UL 60950-1-07
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 32 Watt
- Software Included
- Drivers & Utilities, KODAK Smart Touch, KODAK Picture Saver Scanning Software
- OS Required
- 33 cm
- 16.2 cm
- 24.6 cm
- 5.5 kg
- 10 °C
- 35 °C
- 15 - 76%
